Carlp
I've read up on the relevant posts here and elsewhere, but after a bunch of work, my deck still has the speed issue. Speed varies. The platter strobe advances then stops, advances then stops. I have replaced all electrolytic caps, cleaned/"deoxited" all potentiometers and the two switches (the speed and the shut-down switches), re-lubed the motor and still it varies. Could be "seeking" behavior of the motor drive circuit (which suggests maybe something other than the caps are at play) or perhaps the platter has a problem. One post here talks about replacing the diodes and possibly the transistors.
Here's a quick clip via that video site. I couldn't upload it here, unfortunately. If you look closely you can see the platter bottom edge move up and down along with the strobe marks.
I got this around 2012, discovered the issue and did some cleaning of the pots. Ulitmately put it away unfixed. I now have 16+ turntables and need to start sending them out into the world.
Today I noticed that the platter may have some wobble in it. Meaning the bottom edge relative to the plinth may go up and down a small bit. Motor bearing isn't loose, so it's not that. If there is an issue there (e.g. the spindle shaft might have been bent when it was shipped to me long ago), I could imagine that might cause the strobe marks to appear to advance and hold, advance and hold. Is that possible? That doesn't necessarily mean the motor has speed variations. But I suppose even if the motor is working perfectly, does that matter? Would I still hear wow and flutter in playback? If the spindle speed is constant but it is bent, that might cause the problem I'm seeing, but would it be heard? I haven't put it into the system yet, but I am very sensitive to wow and flutter. Perhaps another user might be OK with it even if it isn't perfect.
I'm wondering if anyone has any strong ideas about where to look next. The diodes in the speed control circuit aren't as simple to replace as one might think, but if it's a likely fix I'll do it. Soldering skills are up to the task. But I'd also like to know if my suspicion about the wobble caused by a bent spindle is a possible cause.
Thank you all!
Thank you all!
