cerwinvegaD9
I picked one up for cheap at a local swap shop and I'm wanting to restore it from the ground up.The cabinet will be refinished and I hope to rebuild the chassis as well,it needs completely rebuilt to be safe to use. The chassis is a 7B01R with seven tubes.My problem is that I have no experience rebuilding a chassis and no experience with working on tube gear. I can solder half decent and understand the process of rebuilding a chassis,I've just never done it before. My knowledge of working on tube gear is limited (higher voltage is about all that I know regarding tube circuits). When I say complete rebuild I mean every wire is cracked, a coil or two are messed up,and I wouldn't trust a single cap in the whole unit. I'm looking for advice on how to go about rebuilding the chassis,or if i should just retrofit a newer unit into the cabinet.
:scratch2:
:scratch2:
