janikphoto
Lunatic Member
I wonder if you could find enough of these in thrifts to make a pair of foster tweeter line array speakers?
Most if not all the Allegros were in boxes that were too small.
That's most of their problem.
I think I disagree with the comments about box size. I believe the Allegros were designed using Thiele Small parameters - oddly, Zenith was one of the earlier adopters of the design method, even if in other areas it was pretty retrograde. An advantage of big corporations is that they have a lot of experienced engineers and designers, and if they want to, they can do things right and efficiently.
Obviously the Allegros were mostly designed to work with Zenith electronics, which limited the amount of power and frequency range that the speakers were expected to work with, and this was probably a limiting factor in the performance of the speakers. But Consumer Reports routinely rated the Allegros highly for their bass within their price ranges, which suggests that Zenith succeeded in wringing what bass extension and power could be found out of what were, and still are, cheap speakers.
Some here have gotten better results putting the drivers in larger cabinets.
