zenith L518 clock radio
steve1a
Hi i,m replaceing the filter cap in a Zenith model L518- 5L03 clock radio owls eye on the filter cap it has 4 lugs in the bottom the lug with the triangle 40mfd 200volts ,and the lug with the square is 80 mfd 200volts on thoes 2 lugs the wires going to them i put in a 100uf 400volt in place of the 80 and a 47uf 400volts in place of 40, the wires on the olther 2 lugs ,are 3 wires going to each. wondering if they tie toghter inside the can, waiting for help, Before i do any more, as what to do with them,most filter caps i have replaced are pretty straight forward with only the lugs for caps this one has 4 lugs and 2 caps,
have a pic of the label from the cap? It should explain what does what and where the grounds go.
