Zenith MT1960
1electron
I have a broken Zenith MT1960 console with turntable, and am/fm stereo. It has a 3L02 and a 7L01 chassis. It just hums louder and louder the longer it is on. I can't find alot of info on this model. I read try changing the caps. It has a big paper cap with 3 different values. 300uf-200v, 300uf-150v, 60uf-150volts. Is changing these a good place to start? If soo i can't find caps with those values. Any help is appreciated. Thanks
Zenith Engineer
Replace both power supply condensers each has two or three taps of different values, just replace them, and also paper/wax types, this will solve your hum problem.
Just FYI 'condensers' is another word for 'caps'. You can replace a cap with a particular capacitance with another cap of the same capacitance but a higher voltage rating, or with a cap of greater capacitance (within reason). Bear in mind that caps are usually +/- 20% tolerance anyway.
Multi-valued caps are hard-to-impossible to find, but can be replaced with however-many discrete single-valued caps.
Be sure all the caps are discharged before you work on them: there are some pretty serious (like, 'potentially lethal') voltages stored in some of them.
Oh, and welcome to AK.
