L-82
Are you asking me? They are in a room 11'x18'. I moved them back a bit last night, that seemed to help. Right now they are 48" from the front wall and the center of the drivers are 16" from the side walls. They are defiantly brighter and less forgiving than vandersteensDo you have a larger room to try them in?
So here is the way the zus sew wired; a 30 foot run from the amp under the den floor in the crawl space to a junction box on the den (then from there I had a bi-wire setup to my vandersteens) I basically took the Bi-wire 6foot run tied both ends together and plugged them in the back of the vandersteens so 2 10 guage wires for the positive and 2 for the negative..... What do you think?
