SET12
Super Member
Seems a few of us have bought these German C-Core Auto-Transformers from Werner in Germany paying around $260/pair which includes shipping.
Thought I would go over these a little with hook up and some measurements.
As you can see is substantially larger then the stock Forte T10A I was using and a bit larger then the Crites as well. I don't have a side by side photo of the Crites and C-Core but if you contrast the Crites to the stock I think you can see that the C-Cores are substantially larger yet over the Crites.
Since sony6060 is building a pair of Forte networks with these and North Creek Inductors I thought some measurement information might be useful.
So here is what I did. The photo on the right of the photo below is the hook up instructions from Werner
My C-Cores have 14 -1db taps otherwise they are shipped with -1.5db taps.
I used my Variac connected between #0 and #15 on the C-Core.
The meters are basically identical models and are very close to one another in measurements being no more than .02 volts difference.
In the photo I was connected to the -8db tap or #8 as labeled and of course #0 for ground (found it to be closer to -9db) and as you can see incoming voltage is 6.33VAC with the step-down being 2.16VAC.
The step down in db for the math is 6.33/2.163 = 2.93
Take the log of 2.93 =.466 x 20 = 9.33db down
I checked the other taps on both transformers and found them the same.
#7 8.0 db
#8 9.3db
#9 10.3db
So I'm using the #8 as this is the closest and would work best for the desired crossover frequency of the Fortes network as designed.
SET12
#7 8.0 db
#8 9.3db
#9 10.3db
SET12
