You can download an O-scope program, most only have minimal functions unless you buy the program, but can't see doing that as you don't need it for anything else.
You need a test record that has the 1khz tone. I have one that has 3 tracks, a L track only, R track only and a L&R track (mono). The deadhead vinyl setup gurus will tell you to play each channel and write down the measurements and adjust till the difference is minimal...Too much work. I used the L&R track (mono) and then use the L+R setting on the O-scope and adjusted till the difference was minimal and pretty much in phase number wise. Since I did not buy the program the details of the wave are not good enough to use that so the digital number output is the way to go, the program would not allow me to over lap each channel wave, only side by side....useless.
I did find it helped quite a lot to my vinyl playback, and my former method was the mirror, magnifier and listening with cans process.
But I would never buy an o-scope.
