Thanks. That’s it. What do you think about getting an amp to go with this stuff? Make a big difference?
This Pioneer SX-550 have MM phono input and if you satisfied with sound then you dont need aditional receiver.
See this review...
http://stereonomono.blogspot.hr/2014/03/pioneer-sx-550.html
Specifications
Power Amplifier Section
Continuous Power Output (both channel driven, 20-20,000Hz): 20 watts per channel at 8 Ω
Total Harmonic Distortion (20 Hz to 20 kHz, from Aux)
Continuous Rated Power Output: no more than 0,3%
10 watt per channel output, 8 Ω: no more than 0,07%
1 watt per channel output, 8 Ω: no more than 0,07%
Intermodulation Distortion (50 Hz : 7 kHz = 4:1 from Aux)
Continuous Rated Power Output: no more than 0,5%
1 watt per channel output, 8 Ω: no more than 0,1%
Damping Factor (20 Hz-20 kHz): 25
Input Sensitivity/Impedance
Phono : 2,5 mV/50 k Ω (+/- 0,3dB)
Mic : 7,5 mV/50 k Ω
Aux : 150 mV/50 k Ω
Tape Play 1 and 2 : 150 mV/50 k Ω
Tape Play 2 (DIN) : 150 mV/50 k Ω
Phono Overload level (THD 0,1%): 200 mV (1 kHz)
Output Level/Impedance
Tape Rec 1 and 2 : 150 mV
Tape Rec 2 (DIN) : 30 mV/80 k Ω
Speaker : A, B, A+B
Headphone : Low Impedance
Frequency Response:
Phone (RIAA equalization) : 30 Hz to 15,000 Hz ±0,3 dB
Aux, Tape Play : 20 Hz to 60,000 Hz +0,5 -1 dB
Tone Control
Bass : +9 dB, -10 dB (at 100 Hz)
Treble : ±8 dB (at 10 kHz)
Loudness Contur (Volume Control at -40 dB): +6 dB (100 Hz); +3 dB (10 kHz)
Hum and Noise (IHF, short-circuited, A network, rated power)
Phono : 70 dB
Aux, Tape Play : 90 dB
FM Section
Usable Sensitivity [Mono/Stereo]: 11,2 dBf (2,0 µV) / 20,0 dBf (5,5 µV)
50 dB Quieting Sensitivity [Mono/Stereo]: 18,3 dBf/(4,5 µV) / 39,2 dBf (50 µV)
Signal-to-Noise Ratio at 65 dBf [Mono/Stereo]: 70 dB/ 65 dB
Distortion at 65 dBf
100 Hz [Mono/Stereo] : 0,15% / 0,3%
1 kHz [Mono/Stereo] : 0,15% / 0,3%
6 kHz [Mono/Stereo] : 0,4% / 0,4%
Frequency Response: 30 Hz to 15,000 Hz +0,2 -2,0 dB
Capture Ratio: 1,0 dB
Alternate Channel Selectivity: 60 dB
Spurious response Ratio: 75 dB
Image response Ratio: 65 dB
IF Response ratio: 90 dB
AM Suppression ratio: 50 dB
Muting Threshold: 14 dBf (2,8 µV)
Stereo Separation: 40 dB (1 kHz), 30 dB (30 Hz - 15 kHz)
Subcarrier Product ratio: 40 dB
SCA Rejection Ratio: 40 dB
Antenna Input: 300 ohms balanced / 75 ohms unbalanced
AM Section
Sensitivity IHF [ferrite /external antenna]: 300 µV/m / 15 µV
Selectivity: 35 dB
Signal-to-Noise Ratio: 50 dB
Image Rejection: 40 dB
IF rejection: 65 dB
Antenna: Built-in Ferite Loopstick Antenna
Miscellaneous
Semiconductors: 3 FET; 5 ICs; 28 Transistors; 21 Diodes
Power Requirements: 110 -120 V, 220-240 V, 50/60 Hz
Power Consumption: UL; 80 W, 185 W (max); CSA; 155 VA
Dimensions (W x H x D): 448 x 141 x 307 mm (17-4/8 x 5-9/16 x 12-1/16 inches)
Weight: 9,4 kg (20 lb 11 oz) net
