My new setup
Turntable is Pioneer PL-115D if I good see. Nice choice.
Type: auto-return turntable
Drive method: belt drive
Motor: 4-pole synchronous
Speeds: 33 and 45rpm
Wow and flutter: 0.07% WRMS
Signal to noise ratio: more than 50dB
Platter: 300mm aluminium die-cast
Tonearm: static balance type, pipe arm (s-shaped)
Effective length: 221mm
Overhang: 15.5mm
Usable cartridge weight: 4 to 10g
Dimensions: 440 x 362 x 159mm
Weight: 6kg
Thanks. That’s it. What do you think about getting an amp to go with this stuff? Make a big difference?
I don't think this receiver has a pre-amp output, so an amp wouldn't be an option. If you're happy with the way it sounds now, I'd say enjoy as is. If you want a bit more volume, maybe looking into a pair of more efficient speakers might do the trick. Do you have a manual? Hifiengine and Vinlyengine have them on their site. Free to signup and download.
Ah sounds great as it. Was just wondering. I’ll checkbout the manual too. Thanks for the input! Seeing some of these other systems y’all have makes me want to get some more stuff lol. Wife would love that! More collections!
You don't need a amp for that it should sound really good with the right speakers! those are great receivers and that is a very nice turntable!
This Pioneer SX-550 have MM phono input and if you satisfied with sound then you dont need aditional receiver.
See this review...
http://stereonomono.blogspot.hr/2014/03/pioneer-sx-550.html
Specifications
Power Amplifier Section
Continuous Power Output (both channel driven, 20-20,000Hz): 20 watts per channel at 8 Ω
Total Harmonic Distortion (20 Hz to 20 kHz, from Aux)
Continuous Rated Power Output: no more than 0,3%
10 watt per channel output, 8 Ω: no more than 0,07%
1 watt per channel output, 8 Ω: no more than 0,07%
Intermodulation Distortion (50 Hz : 7 kHz = 4:1 from Aux)
Continuous Rated Power Output: no more than 0,5%
1 watt per channel output, 8 Ω: no more than 0,1%
Damping Factor (20 Hz-20 kHz): 25
Input Sensitivity/Impedance
Phono : 2,5 mV/50 k Ω (+/- 0,3dB)
Mic : 7,5 mV/50 k Ω
Aux : 150 mV/50 k Ω
Tape Play 1 and 2 : 150 mV/50 k Ω
Tape Play 2 (DIN) : 150 mV/50 k Ω
Phono Overload level (THD 0,1%): 200 mV (1 kHz)
Output Level/Impedance
Tape Rec 1 and 2 : 150 mV
Tape Rec 2 (DIN) : 30 mV/80 k Ω
Speaker : A, B, A+B
Headphone : Low Impedance
Frequency Response:
Phone (RIAA equalization) : 30 Hz to 15,000 Hz ±0,3 dB
Aux, Tape Play : 20 Hz to 60,000 Hz +0,5 -1 dB
Tone Control
Bass : +9 dB, -10 dB (at 100 Hz)
Treble : ±8 dB (at 10 kHz)
Loudness Contur (Volume Control at -40 dB): +6 dB (100 Hz); +3 dB (10 kHz)
Hum and Noise (IHF, short-circuited, A network, rated power)
Phono : 70 dB
Aux, Tape Play : 90 dB
FM Section
Usable Sensitivity [Mono/Stereo]: 11,2 dBf (2,0 µV) / 20,0 dBf (5,5 µV)
50 dB Quieting Sensitivity [Mono/Stereo]: 18,3 dBf/(4,5 µV) / 39,2 dBf (50 µV)
Signal-to-Noise Ratio at 65 dBf [Mono/Stereo]: 70 dB/ 65 dB
Distortion at 65 dBf
100 Hz [Mono/Stereo] : 0,15% / 0,3%
1 kHz [Mono/Stereo] : 0,15% / 0,3%
6 kHz [Mono/Stereo] : 0,4% / 0,4%
Frequency Response: 30 Hz to 15,000 Hz +0,2 -2,0 dB
Capture Ratio: 1,0 dB
Alternate Channel Selectivity: 60 dB
Spurious response Ratio: 75 dB
Image response Ratio: 65 dB
IF Response ratio: 90 dB
AM Suppression ratio: 50 dB
Muting Threshold: 14 dBf (2,8 µV)
Stereo Separation: 40 dB (1 kHz), 30 dB (30 Hz - 15 kHz)
Subcarrier Product ratio: 40 dB
SCA Rejection Ratio: 40 dB
Antenna Input: 300 ohms balanced / 75 ohms unbalanced
AM Section
Sensitivity IHF [ferrite /external antenna]: 300 µV/m / 15 µV
Selectivity: 35 dB
Signal-to-Noise Ratio: 50 dB
Image Rejection: 40 dB
IF rejection: 65 dB
Antenna: Built-in Ferite Loopstick Antenna
Miscellaneous
Semiconductors: 3 FET; 5 ICs; 28 Transistors; 21 Diodes
Power Requirements: 110 -120 V, 220-240 V, 50/60 Hz
Power Consumption: UL; 80 W, 185 W (max); CSA; 155 VA
Dimensions (W x H x D): 448 x 141 x 307 mm (17-4/8 x 5-9/16 x 12-1/16 inches)
Weight: 9,4 kg (20 lb 11 oz) net
Very nice combination. Gets down now to it's condition, the cartridge/stylus and last but least the speakers. What speakers are they?
