One of the reasons I'm fully convinced a lot of audio folks never really just sit and enjoy with an empty mind.So, the more mods you make the more you will need to make even more mods?
I'm not entirely sure what was meant. That modded gear is more revealing, so each change makes the impact of later changes easier to hear, I think. But indeed one can question whether it is the ears that are improving more so than the gear. In any case, I think you do see cases where the need for further change is just enhanced rather than quenched.It reads more like practice makes perfect.
Really? They pay someone to maintain and sometimes mod that sound reinforcement system.Except that all that practice will never get you to Carnegie Hall...
The resolution of modern equipment is far far better than the human ear. If it isn't measurable, then it cannot be audible.Doubt it is measurable, but might be audible.
How do you measure sound stage width, depth, height and layering.
...for example that the Neutrik Speakon connectors are only good up to 200Hz.Danny Ritchie - GR Research claims...
Those are human perceptions of sound quality, not electronically specified & generated ones. Different listeners can have different perceptions of S.Q. listening to the same piece of equipment.How do you measure sound stage width, depth, height and layering.
I'm of the "if you can hear it, you can measure it" camp. And if you can't measure it, you are not measuring correctly.
The capabilities of even older test equipment is quite extraordinary.
typo?...for example that the Neutrik Speakon connectors are only good up to 200Hz.
You're describing very measurable differences in the acoustic environment, ain't no mystique here.All I know is the exact same audio set up sounds different in my workshop than it does in the dedicated, acoustically treated listening room. The room and placement of gear in the room is the only difference and it is very audible.
