They are using "paper former" coils in them now, by default. The Kapton former coil is still specified in the E130s (which is correct for them), but they do use the correct coil now for the D130/D130F.
AFAIK, all the other parts were always correct.
As for D130 vs. D130F- according to Harvey Gerst (who was a lead tech there at JBL during the D130F development)- there was only two significant functional changes made to the D130, and they were independent of the release of the D130F as a Fender-badged product. One was an "opening up" of the magnet gap clearance to the coil, from about 7 mil, to about 10 mil, to avoid voice coil rubbing issues when the frame flexed as they were torqued down into a guitar cabinet. The other was, adding the treaatment to the paper flex surround, to reduce cracking. These steps were pretty much independent of anything that people like Dick Dale might have done in terms of blowing up speakers and such. Mind you, the increase in voice coil gap DID probably improve the resiliance of the driver in the case of overheated coils (they had to deform more under heat before rubbing), but that was a side effect of what they were already doing to address production and existing warranty issues.
Regards,
Gordon.
