I have been thinking about this move, and have talked about it enough, so here we go. I included some pics of the tear down, and in them you can see just how many staples I put in the bottom of each speaker, what a PITA to remove. I must say that the nice set of folding pliers I got from my AK Secret Santa worked perfectly. Thanks Santa! You will also see were I previously repaired the voice coils using peter Gunns DAP method. Almost two years of mucho play time and they are holding up nicely. The Ribbons new at the time of repair show no signs of wear either. I plan on replacing all the wiring with silver stranded 22 ga, altough I might use OFC Copper on the base panels. Any thoughts? The Midrange/Ribbon Crossover will go outboard, and the input plate will be set up with upgraded 5 way connectors for tri-amping. I will also do away with the staple panel attachment method and use a more solid method to hold them in place. It looks like maple will be the wood used, mainly due to availability at a very reasonable cost. A friend is helping me with the frames, and we hope to have them done by next weekend so I need to get some parts ordered asap!
Regards,
Jim
Regards,
Jim
