1/4" super mat.
langston
Hello
Will KAB's 1/4" super mat function properly on AT's lp120usb turntable eg: allowing record proper spindle seating?
I wasn't sure. Based on photos it seemed to thick.
Beatcomber thanks for the confirmation.
Do you have the AT? If so, how thick is the mat on it? The KAB mat, as advertised, is 1/4" thick so if the AT mat is too then you're okay.
If the AT mat is less than 1/4" thick, how far does the spindle protrude from the platter (without the mat in place) before any bevel or other reduction in its diameter? I'd say anything around 1/2" would be plenty for a 1/4" thick mat.
John
John
The AT makes use of a felt mat.
When I had an AT-PL120, I put a 1/8" rubber mat on it and there was plenty of clearance for the spindle. A 1/4" mat will be fine (and will be a big improvement over the felt mat).
I ordered.
1. 1/4" KAB mat.
2. One overhang gauge.
I tried felt, cork mats. I thought time for a thick rubber mat.
Also seems this AK'er used a 1/4" KAB mat AT-PL120 owners on a 120.
I just got done auditioning the 1/4" and 1/8" mats on my AT-PL120. The 1/4" mat to me sounded powerfully overdampened. The 1/8" mat however seemed to bring out the life in recordings and open up detail, and it did this with different cartridges. It is a big improvement over the stock felt slipmat and the homemade cork mat I had been using.
