Show us your DIY speaker projects!
Dan ʕ•ᴥ•ʔ
Peanut Head
Okay, I'll start the ball rolling with a few I've done. The first one is a powered subwoofer in a sealed 1.30cu/Ft cabinet, utilizing a Peerless XLS SWR-308 12" woofer and a Keiga KG-5230 plate amp, which has a 4dB boost @ 25Hz. System response half-powers @ 27Hz. The cabinet was constructed out of one-inch 11-ply Baltic Birch plywood with a Pecan veneer.
attachment.php
The next one is a small bass-keyboard cabinet. My intention with this was something that would be the ultimate studio and practice cabinet. Bandwidth and a small footprint were my goal. SPL output is good for its size, but sensitivity is down by comparison to MI cabs, which generally have less bandwidth, unless large cabinets (and the appropriate drivers) are used. I used a Vifa dual-concentric mid-tweeter and a Pyle PLW-12 woofer. Crossover is 1500Hz, 2nd Order for the Vifa with a switchable pad. Tweeter also has a poly-switch for added protection. The woofer rolls off just above 1500Hz, so I didn't use any filtration on it. Cabinet is 1.53cu/Ft, sealed, 3/4" MDF, covered with Tolex. Half-powers @ 40Hz, average sensitivity is 89dB per 1w/1m. I changed over to Speakon connectors on later builds.
attachment.php
Celt,
Very nice! I really like the Pecan veneer! Wish I had the space/room to do the scratch stuff...I have enough trouble doing the refinishing work.
Thanks ARguy! :) I also wanted to remind members that many pics they may have shared in the past, were lost when the server last crashed. Even if you've already shared your projects, please upload the pics again! AK has many new members that haven't seen them and many of us *old guys* would like to see them again.
Hi Gordon! I just visited your web site! Very fun! I especially enjoyed reading about the "Morgan" project. Very cool indeed!
My Shiva Sub
Here's my sub. Have also made a pair of Fostex FE103E and BK16 horns and modded a pair of Karlson K15s.
Gary
Here's one of four horn cabs I made to stack on some 15" PA cabs, Crate PE15H, I have for my current PA system.
The small horn tweeter (P*Audio PHT-408) in the cabs is somewhat harsh so I wanted a smoother horn and driver. I chose the CTS KSN-1196 5" x 15" horn lens and CTS KSN-1188a piezo driver. This is the large "PowerLine" model that has a protection circuit to 400 watts and goes down to 800 hz.
Actually it goes lower, down to about 600 hz, but is cleaner if crossed higher at 800hz-900hz. I placed a resistor in parallel with the 1188a so that it acts like a regular driver, and in series with that is a capacitor so that it rolls in at about 850 hz at 6 db/oct.
There is also an inductor and capacitor, forming a 12db/oct low pass going to a "woofer out" socket on back. This horn box is stacked on top of my fullrange cab, and a 3' jumper run down to it. Since 850 hz is far below the crossover to the cab's built in tweeter, that harsh tweeter is out of the picture. And the woofer is rolled off at a frequency more suitable to a 15" woofer.
The result is a much cleaner, more relaxed and natural, near hi-fi sound. Yet the horn can be left at home and the cab only used as a full range if necessary.
I used the same black Ozite carpet that the manufacturer used on the full range cab. I changed the Crate's corner protectors over to the "Chevron" locking type from Rean. Everything stacks and interlocks well, and looks like it was made to go together. Unseen, there is a strap type handle on the other side of the horn box, like those used on guitar amps.
This is just the most recent project. It resulted in a much smoother PA system that is still small and easy to move around, quick and easy to set up. There are four of those 15" cabs and four horn boxes to stack on them. This means the amp is running into 2 ohms, which it handles easily... and was designed to do so.
Next on my workbench, my older son, overseas right now (Army), has me building a pair of 7pi-18 kit's from www.pispeakers.com. These are three-way all horn systems. The bass section is a corner horn with Eminence Kilomax-18. Yes, 18" woofer... MORE POWER!!! Tim Taylor would be proud. The mid is a wood horn driven by an Eminence Delta-10. The tweeter horn is the Eminence PSD-2002 driving their H290 horn lens, a very fine combo.
When I finish those, I'll get around to replacing my old Speakerlabs with some 4pi Theatre's from Pi Speakers. These have the same Eminence PSD-2002 and H290 for the top end, and Delta-15's in 7 cft ported boxes for the bass.
I'll be taking pictures of all this and doing step by step threads.
Quinnster said:
heres a pair of dj speakers i made a couple years back, really ugly, but got loud!!
Not ugly at all... just unfinished! That's nothing some Ozite carpet and 3M77 won't fix. Or take the drivers out, coat it with truck bed liner, reassemble.
Truck Bed liner coating + PA Cabinet = very good idea. Makes 'em virtually indestructable. If it's good plywood underneath, you could virtually use 'em as a boat. :D
Regards,
Gordon.
Quinnster . . . I have seen plans for this before. :scratch2: Glad to hear that it is as advertised. What kind of sub is that?
Here are a couple I have done, well working on. As you can see the big horns still need veneer. I actually have the sapele pommele, just haven't had the time to apply it. They use Altec 416-8C woofer, Altec 802-8G mounted to a 511B horn and a JBL 077 tweeter. Then there is the corner horn loaded with a JBL 2220, LE175 driver on a H91 horn and finished with a L94 lens.
