X202B time capsule
RS Steve
Tube Junkie
Just thought I would share my newly aquired X202B with the Fisher community. It had been stored for a good 25 plus years. I took pictures as I removed it from the original box, from what I can tell it is all original with very little use. I will do the dim bulb start up very soon, but will probably have a routine restoration done to insure a long and happy life.
more pictures.
Saw this gem on ebay and was drooling! First a sony6060 restored TA-800 and now THIS!!?? NOT FAIR. WAH.
:cry:
that's a beauty,makes one wonder just how many of these tube Fishers are packed away in peoples storage.I get excited when finding the early original tubes that came with the early tube amps.Whats the tube lineup in this unit?
hunter
hunter
I get excited too finding unrestored original equipment, this has 7591 output tubes, 7247's, and 12A7 - ECC83's in it, all say Fisher.
I found it in the ebay sold listings. it was just around the corner from me in palo alto.
quite a acquisition. congrats
Thanks guys, sometimes you get lucky and find something you have been searching for, timing can be everything. I have my dim bulb tester finished, now comes the fun part. :music:
Some guys have all the LUCK! And the $$$ to go withit. :D
It came up at just the right time, I parted with my Marantz 2325, X101C, CV D5's, and a Sony receiver so the $ was there. A no brainer it was.
I just did the dim bulb test and it shows it is good to go, just wondering if I should deox the controls before hooking it up and trying it out.
Wouldn't be a bad idea to give it a douche. Kinda like greasing the ball joints on a car that's been sitting for 20 years before running it on the cobblestones around the corner.
Keep an eye on the temps of the Can caps. If they heat up (other than radiant heat from adjacent tubes and transformers) shut it down. If you have a variac, I'd try to at least bring it up to wall voltage slow (over an 7-8 hour period) to help the caps form back up. Don't shock them with wall voltage right off, if they are weak they might blow. Dim bulb tester throttles the voltage and the current to reduce damage.
Start at 30 volts and increase 10 volts an hour until you've spent an hour at 90V. Then 1/2 hour per 10volts up to 120V. keep an eye on the can cap temps. If one or all heats up fast shut it down and replace them. Also look for weeping from the center vents on them BEFORE powering up. If they've vented, don't plug it in.
If you don't have a variac, use a 40w bulb for an hour, a 60w bulb x1hr, a 75w bulb x1hr then a 100w bulb x1hr. This does the same basic thing, but a bit faster. Same deal keep an eye on the can caps.
Larry
Larry
Thanks Larry, do I have the unit just plugged in with no source or speakers hooked up?
