Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
The 6CW5 is an EL86 & of course the 6BQ5 is the EL84. They are similar but I believe there's a voltage vs current trade-off (see below) - apparently the EL86 needs lower plate voltage but higher plate current for the same power output vs the EL84. http://www.r-type.org/exhib/aad0122.htm
I've not used the 6CW5 but here's a discussion on the two:
I seem to remember a thread here a few months back on this, using 6GH8, 6U8, 6AN8, & others as various subs. IIRC the Scott LK-72 has two versions, one with 7199 and one with 6U8/6GH8 PIs.
Edit: the 6GH8/6U8 is not a direct replacement sub for the 7199 but was used with appropriate pin/wiring changes.
Seems like a useful tube, being able to get 25 watts out of a pair with 1% THD and only a 3ka-a load (which makes it easy to get really good frequency response from the OPT)...
Notice down at Post #5, Tubular Joe suggested the 7687 as a good tube that behaves like a 7199 (the 7687 pin out is same as 6GH8 - and different from 7199).
Sylvania introduced the 7687 as an alternate to RCA's 7199, but in the pinout of a 6U8 / 6GH8 (it's taller too). I think their data sheet says that the characteristics are the same as the 7199. I doubt you'll be able to find any for much less than a 7199, though, as it isn't very common. 6BL8 may be the next closest one in the 6U8 pinout, but 6U8 and 6GH8 are sometimes used. 6AN8 may be closer than any of those, but it has a unique pinout different from all the above.
Back to the original question - 6BQ5 MIGHT work for 6CW5, but don't try the reverse - 6CW5 has much lower voltage rating. Russian 6P15 (SV84) may be close... also 6HL5 is listed as a sub, though the pinout is slightly different. But having FIFTY 6CW5s and ZERO 6HL5s, that doesn't strike me as particularly useful information...
