Check voltages if you're using anything but a 6GH8 - the characteristics do differ, and it's a direct coupled circuit, so the bias on the phase inverter (critical for maximum clean output) is set by the plate voltage of the preceding stage. With that in mind, you can also try 6EA8, 6BL8, 6JW8, 6KE8, 6HL8, 6LM8...
