That's a bunch of nonsense. There's more to good bass than whether the speaker is ported or not. Speaker and driver design (including materials used in construction) is a good place to start. As is placement in the room.
I think that good designers will choose a ported or suspended design based more on design parameters they've been given to work with. There are lots of speaker manufacturers who use both ported and suspended designs.
My B&W 603s have two ports: one for the mid chamber and one for the bass chamber. They have very tight, clean bass. But, if I move them close to the wall behind them, the wall reinforces the bass coming out of them and makes for an almost overwhelming bass sound. But you'd run into this issue irrespective of whether the design was ported or suspended as it's the room interacting with the sound after the sound is out in the room, not while the sound is being generated by the driver.
I have plugs I can put in the ports, but my room is big enough that my speakers sound better with the ports unplugged.
The damped ported or aperiodic approach -- as advocated by Fried, Dynaco, Von Schweikert and others -- may be the best approach of all. Stuffing the port in a controlled manner allows the Q at resonance to be adjusted for critical damping, thus providing better transient response than an undamped ported alignment.
That said, I'll add that I've heard and owned fine-sounding examples of air suspension, ported and aperiodic speakers over the years. IMO, quality of implementation is more important than the choice of design approach.
