MuthaFunk
Vinyl Addict
I just got my new JD9 from Shenda Jolida. After reading the story on www.jolida.net about 2 Jolida companies competing for the same market share I was curious about what quality I would expect to see from the cheaper priced Jolida Shenda JD9. I have long wanted to preview a JD9 and took this opportunity to try one.
I have a background in audio engineering as well as electronics and instrumentation, so I can appreciate excellent sound and build quality. I would like to ask the help of you fine people who have a Maryland JD9 to do a physical comparison of the Shenda JD9 vs the Maryland JD9. Here is a link that informs you how to tell what factory your Jolida came from:
http://www.jolida.net/jolida_inc_warning_part4.htm
IMO the Maryland JD9's look better, at least the black with gold lettering does in my eyes. My observation of the Maryland JD9 looking better is only based on very few photos I was able to find on line.
It was frustrating for me to choose which Jolida I wished to order from. I thought the Maryland JD9's looked like they were finished a little better on the outside but after reading the story on the Shenda web site I believed them and ordered form www.jolida.net in hopes of getting better internal build quality and parts. It was my belief that they had truly been the original designers of the JD9 and probably built many more of them than the outsourced company the Maryland Jolida was using to construct their JD9's.
The truth is, I don't care who is the real Jolida, I just want to know who's making the better product or are they the same with only minor cosmetic differences.
Here is a slew of photos of my Shenda built JD9:
Bomb proof packing anyone?
I have to say I was really surprised at the weight of the unit!
Here's some closeups of the finish on the front.
The rear of the unit is impressive as well at this price point!
I love the etched dip switch position indicator... so shiny!
Onwards to the internal components photos!
The first thing I noticed was the capacitors look like cheap Chinese ones but a little research revealed differently.
Now these Rubycon caps are used throughout my JD9 and they are by no means "High End" caps, but what I did find is they are at least as good as most mid fi equipment. You can compare the data sheets between the Rubycons XYA and the well regarded Panasonic FC series at these links and see they are the same specs.
http://www.rubycon.co.jp/cn/catalog/e_pdfs/old/aluminum/e_yxa.pdf
http://www.panasonic.com/industrial/components/pdf/aba0000ce22.pdf
The stock op amps on my unit look to be decent as well:
Here's the data sheet:
http://pdf1.alldatasheet.net/datasheet-pdf/view/27258/TI/OP37G.html
Notice the Op Amps are not directly soldiered to the board but inserted into sockets. For the purist, this is not fine craftsmanship as it adds a connection point but I look at it as a feature allowing the upgrade of the op amps by a novice without any soldiering equipment.
Continued....
Continued....
