CharlieDont
Hey there,
I’ve got a TEAC reel-to-reel I’d like to fix up for use to record for fun. I have never run the motor yet. When I first plugged it in I checked the voltage from chassis to ground I got a 50V reading. I figured that meant I should probably (1) add a grounded cord and (2) recap the power section. Before doing anything though, I wanted to make sure too be aware of basic maintenance. Reading a bit on the forums here and saw the 0.1uf Suzuki really need to go. I have some of these on hand and wondered if they would do the job- from what I understand metal-film is good but maybe it specifically needs an a VAC rating. From hearsay it sounded as though if it has a really high DC rating the AC rating should be about two-thirds of the VDC rating? Anyway just wishing for some insight into that question. Do I need to order some of those yellow film caps with an explicit VAC rating or do these panasonic 630VDC film caps do the job just fine?
All the best,
Charlie
https://www.mouser.com/ProductDetail/Panasonic/ECQ-E6104KFB?qs=9ouE0kzBZ2qb/N/pLDqD5Q==
All the best,
Charlie
(Elna's on my s**t list too. Have always been a fan of Pana and Nichicon caps.)
