Dr. Gizmo (as far as I can tell) pretty much single-handedly drove the resurgence of interest in DHT SE amplifiers, at least in the US.
As to the even/odd order harmonic distortion... this is NOT a tube/transistor difference; it is a single-ended/push-pull difference. Even-order harmonics cancel out in a push-pull amp; but not in a single-ended amplifier. Tube amps tend to have proportionately more lower-order harmonic distortion. Put those two factoids together, and the even/odd order fallacy just seems to spring up.
http://www.audiokarma.org/forums/showpost.php?p=2905128&postcount=31
Note: so the pitch known as "concert A" in music has by convention a frequency of 440 Hz. That's the A above middle C for those as musically challenged as I. Folks would call the base frequency of 440 Hz (A440, aka "A4") a "fundamental" (tone) if you struck that key on the keyboard. Double that frequency is 880 Hz. You might be tempted to call that the "first harmonic" but it is in fact referred to as the second harmonic (which is the first even order harmonic distortion product of the fundamental). 880 Hz is also the fundamental frequency of "A5", i.e., the "A" note one octave above A440. Needless to say, if you have a single-ended amplifier (tube or solid state) with a significant amount of second harmonic distortion, the result will be "euphonious" -- the note and its partner one octave up. Is it accurate? No. Is it pleasant to hear? Yes.
http://en.wikipedia.org/wiki/Piano_key_frequencies
http://en.wikipedia.org/wiki/A440
that you can make any good quality amp sound like a tube amp by inserting a 1.5 ohm resistor in series between the positive erminal of the amp and the speaker.
You can doo far worse than to be a Nelson Pass fanboy!![]()
(and seriously that NFB / distortion piece is a great read... just a random tidbit - blind testing shows people split between preferring small amounts of 2nd and 3rd order distortion aka SE vs. PP... so much for the commonly accepted "even order always sounds better" rule.)
It's when you get into higher harmonics (4th, 5th, etc.) that even-order sounds less offensive. High amounts of either 2nd and 3rd harmonics will "richen" and "detail" the sound in an undesirable, yet subjectively good way, in the same way that a well-tuned 12-string guitar sounds "fuller" than a six-string counterpart.
I've also heard of the Pass method, and while I've not read his results, my own indicate that the effect is largely dependent on the speaker.
Mark, I remember reading at the time that wirewound types were specified because the resistance element coil winding added inductance to the mix, and that was the primary reason for the treble rolloff, leaving the bass unaffected.I would think that you'd want to use noninductive resistors for best results.
I tried it...I like it better, as my highs were a tad bright anyway...but Im still listening.
I wish I could remember precisely where I saw the original article, but it was around the early 80's or thereabouts.
Tom
