10.7mhz tuning
Ya it was 20 seconds. I’m going to have to do some research because all it say is connect a sweep generator and adjust cans for highest amplitude.
Usually you'd set the start frequency a bit below 10.7 MHz and stop a bit above. Maybe use 10600000 and 10800000. Sweep time fairly short, maybe 250 ms.
With sweep generators its not just the highest amplitude, you also want symmetry. Often it means sacrificing a little bit of peak to get both sides of the peak to be the same shape. Having it unbalanced increases distortion.
