Next on the list to change out is the Power Transistors once I find the correct part number to replace them. Do you think that could be the cause?
I was referring to the Power and Ripple Filter boards (F1246, F1251), not the "power transistors" (by which I assume you are referring to the output transistors?). Sounds like petehall is going to walk you through the diagnosis process. Good luck with it!!
