Richs_Trains
Well-Known Member
Okay, so I bought a 1090 on craigslist for $50.00 to use for parts for a 1090 that I recapped. This unit was filthy inside and someone had pulled 1 output transistor from each channel, a 588 on one side and a 618 on the other. I was just going to take the cosmetic parts I need and trash the rest, but I just couldn't do it. I had bought some transistors from China and was advised here that they are probably fake, so I didn't use them in the 1090 I recapped, but thought I would throw them in this one and see what happens. Firstly, whoever pulled the old transistors used the heat and rip method and did not remove the old solder before removing the chips, so the board and the foils are a mess, also there are several spots where they did work and burned off the foils. I jumped with wire all that I could find, installed the new (China) transistors and used a dim bulb to test. No light, no fire, so I went for real power and connected a tuner and speakers. I get sound, very poor and very distorted and I get no reading across output transistor emitters for mA and should be around 12. Are my bias transistors shot or are the China outputs garbage and just I'm hearing the headphone amp out the speakers? Should I keep trying or is this a unit for the scrap heap (I hate to trash any Marantz). Thanks for your help and advise.
