Jailtime
Standin' on a corner
Got an 1152DC on the bench now, it's giving me the run around. With the preamp engaged, the right channel has unstable DC offset (about 50mV fluctuation). The right channel also has a low level pop/fizz noise in the speaker, not affected by volume or input. Left is quiet.
With the pre isolated from the main amp, the right channel DC is stable. Both channels are quiet with the pre isolated.
I tested it at 30Hz, 1KHz, and 15KHz on the scope, output on both channels was clean and even. Made good power at 92 WPC.
So the power amp is good, that right preamp channel is driving me nuts though. It is recapped, and has all new small transistors in the amplifer board, power supply and preamp section. The heatsinked drivers in the amp are original. I also re-soldered the pin connectors for the preamp board. I'm at a loss where to look next.
