The problem is heater voltage. Its too high with power transformers with 110v primaries.What exactly do you have that will only run at 110 volts? While US power is 120V nominal, traditionally you could expect to see anything between 110 and 125V, and pretty much everything will work fine in that range.
Your right, a bucker would be cheap enough to build. I have a nice 6v, 6 amp transformer with a center tap.Take a look here...
https://robrobinette.com/5e3_Modifications.htm
Scroll Down to "Build a Bucking Transformer". I'm working on one now. My wall voltage typically runs around 122 to 124VAC. My lowered voltages with the BT turned ON were 109VAC and 115VAC on the two outputs.
I've done that before with several old poin to point built console amps, etc., but these are built on printed circuit boards that are double sided with some of the traces buried.Since
Since heaters are a constant load, perhaps inserting a resistor in the circuit would help.
In case anyone was wondering this is the Bucking Transformer I built.
Nice build. I think I'll build one with two outlets on switches. Then I can switch between 7% and 12% on either outlet. Usually when modifying old console tube amps, or using old transformers for amp builds, I just adjust the dropping resistors. But I have bought a few pieces of equipment made in chinafilaments. PCB'S and 110v primaries. One phono preamp I was able to easily replace the resistors for the tube heaters to lower the voltage back down to 6.3v. But a couple others it's just a pain to remove the PCB's and find the traces buried in the boards.In case anyone was wondering this is the Bucking Transformer I built.
You selling any? I’ll take one or two.In case anyone was wondering this is the Bucking Transformer I built.
I love that!In case anyone was wondering this is the Bucking Transformer I built.
that doesn't make for an especially clean sine wave though. There will be about a half volt "gap" either side of the zero crossing where the voltage is below where the diode switches on. The switching I would expect to introduce some harmonics to the wave, not sure if it would be audible or not.
motors aren't audio gear though. AC motors don't love dirty power either, if you've ever heard the horrible racket that a ceiling fan connected to a dimmer makes, much of that is from the nasty switching from the triac. Thats at a much higher voltage though so probably more severe. Aren't train motors a universal series wound setup too? That type runs on AC or DC, so probably fairly un-fussy about what feeds it.
