funktheory
Im obviously not very good at this. If i touch the leads together i get 00 ohms, actually getting a reading is so tricky as the points are so close together but i will persevere
What should it be on , on meter?
Im obvviously not very good at this- i tough the leads together i get 00 Ohms, trying to get the reading from the cartridge is so tricky but i will get there in time...
I see no mention of the cartridge being used.
LOMC into a MM phono stage![]()
He posted a pic of an Ortofon Concorde type earlier. AFAIK none of those were MC.
No its a fair enough question
A separate RCA Cable goes from output channel to the audio output of a Lepy LP-V3S.
Im at a loss!
No its a fair enough question as i cant work out where im going wrong!
So heres the setup:
Technics 1210 mk2
This plugs into a Fosi Audio BOX X1 Phono Preamp
Both RCas plugged into the input Channels.
A separate RCA Cable goes from output channel to the audio output of a Lepy LP-V3S. theres not a phono input, could this be an issue?
Then it goes from there 4 speakers terminals, plus and minus for left and right
Speakers are B406a Speakers
Are they passive? I couldnt find anywhere that says they are and they are 80w so is the amp powerful enough to drive them? Currently when rigged up as described, i can feintly hear the music through the speakers and lots of hum!
All turned on.
Im at a loss!
