is this a multi-voltage unit? what is the voltage setting? what is the line voltage. no guessing - MEASURE IT.
are these original transistors on the stabilizer board? it really should go higher. what are the awr-106 pin 6 and pin 15 voltages? Should be +85 and -87.5v respectively.
I've typed this before too:
9.3.1 turn VR2 to zero ohms indicated.
9.3.2 ignore the effing jumpers
9.3.3 turn the volume to zero, no sound! eff the extra resistors
9.3.4 speaker switches OFF / OUT!!!!
9.3.5 turn on power
9.3.6 if you used the two VR1 500 ohms 12 turn offset pot 652-3266P-1-501LF $2.94 ea it has 12 turns, the 3296 had 25 turns!!
it will feel like it is freewheeling. W ATCH the voltage between pin #9 and ground. your target is 0.000v. it WILL eventually get there.
when it gets between +0.010v and -0.010v you are DONE, do the next step
9.3.7 move the voltmeter to read TWO volts maximum with the RED lead connected to pin 7 and the BLACK lead connected to pin 19. adjust VR2 to cause the meter reading to go to 0.100 volt.
9.3.8 let it warm up a bit, then go back to step 6 and see if the 0.000v reading has drifted, and correct it. then do the same for step 7.
then START all over again on the other channel.
yes, they will not be stable when being picky looking at the millivolt variations. they are a bit more stable when I redo amps COMPLETELY with all new transistors.
