consolrepair
Member
There are quite a few on Parts-Express - This one seems to be highly reviewed: https://www.parts-express.com/peerless-by-tymphany-d27tg35-06-1-silk-dome-tweeter--264-1022
Interesting, why did you go with a 12" over, say, another 8 inch?
Thanks, so just wondering if this tweeter would work. It's 6 ohms. I've been trying to figure out what the ohmage is on the current speaker but I'm having trouble figuring it out. There's nothing glaringly obvious on it that I can see that indicates what it is.I changed all of the drivers in mine. They were all the same size but not the same brand. I also put proper 3 way crossovers in there, salvaged from a set of Infinity speakers. Mine ran the 12" full range, and the 5" and the 3" were both wired through a simple cap to keep the bass out. It was way too loud in the middle and had very weak top end. Not much for bass either. The University 12" speakers I subbed for the original woofers helped with the bottom end. The replacement 5" and tweeter gave it a lot more top end without the big hump in the midrange. I also lined the cabinets with thick cotton batting. Its all pretty subjective but I'd say it went from maybe a 3 to a 7. Its not as good as my main system but it went from something that I really didn't want to hear to something I will actually listen to.
Interesting. Now that I've thought about it, I'm pretty sure it's 8 ohms, at least for the tweeter. I had taken a reading on them a while back to make sure they were functioning, and I believe the one on the right side measured out at 7.2, and the one on the left side (the one pictured) was 7.8not honestly sure. DC ohm measurement would probably give a hint. If its in the 2.5-3.5 ohm range, its probably 4 ohms. 5-7 ohms is probably 8 ohms. Also depends how those two speakers are wired. If its a pair of 8 ohm drivers in series, that comes out to 16 ohms, and 5 uf with 16 ohms is 2000 hz.
