now you're into the realm of needing hands on experience with these, and thats something I do not have. I'm working purely on theory and guesswork here. I don't know precisely what the channels are capable of.
sticking a bigger transformer in without doing anything else will do nothing for max power output at mid band. It may improve performance at the bottom end if the original transformer was saturating.
Power isn't quite directly related to transformer size but there is some relationship. More power needs more current and/or more voltage. More current needs fatter wire, which takes up more space. More voltage needs more insulation which also eats space. It is possible to make a lot of power with fairly small transformers, but they will be frequency limited. Low frequency performance needs a fair bit of inductance, which tends to mean more iron in the core so it doesn't saturate. Single ended amps need even more iron because they don't have the benefit of a self-cancelling magnetic field.
so the left and right transformers on the Motorola can be small mostly because they don't have to deal with any bass.
