Thanks! I downloaded the schematic they attached and I’ll bring the technician a copyGive him a copy of the schematic too if you can. Maybe Dswanky will e-mail it to you. The tech will have to add a jumper wire in that molex connector to power the amp up.
Good news! I found a record store 45 minutes away that has a technician willing to work on my amp! At first they said they can’t do a console, but when I mentioned I could bring the amp, they said they’re happy to test and repair it. I guess it’s just a small shop so they don’t have a lot of room. I’m going to have my father in law help me remove it safely and reconnect it when it’s fixed up. Any tips for transporting it safely? And anything else I should consider? Thanks for all your help.
...that molex connector to power the amp up.
From his picture looks like it has Mullard 6BQ5's. They have those blotchy spots. Mine came with Magnavox Mullards. I'm still using two in my DG1 amp. One finely lost vacume.As for transporting it just wrap a blanket or similar to make sure you don't break the tubes, It'll fit inside a regular size cardboard box so set it in there with it wrapped up and other then bouncing off pot holes, bumpy roads you should be fine.
One last thing, those original tubes maybe 60+ yr's old but that doesn't mean they need to be replaced. If the tech says they need to be replaced with "new" be sure to ask him why and can he provide the test scores to back it up.
One of the beauties of Magnavox amps is they used good tubes and more times then not even after 60yr's they're still fine.
There should be plenty people in your general area that would be willing to help you out. I am in SW Washington in the Kelso/Longview area.I’m in southern Oregon the Rogue Valley Area
If keeping the console, the only mod I would possibly make to it is installing a more modern turntable with an inexpensive phono preamp. It would sound a lot better than that Turntable with a crystal cartridge. You wouldn't have to destroy the original turntable or mod the console itself.There should be plenty people in your general area that would be willing to help you out. I am in SW Washington in the Kelso/Longview area.
Personally, I wouldn't put other guts or speakers in that console but rather build or rebuild it as stock because those speakers are only rated at 10 watts and are voiced and designed just for that console. I can't even begin to tell you how many of those speakers I have yanked out of those consoles only to find out that they sounded really shitty when put in individual boxes or cabinets. In the original console, they sound great. Also being only 10 watts, I can't begin to tell you how many I have blown by just hitting the power button on some high power amp I was using at the time. Does the word "Phase Linear 400" power amp mean anything to you?![]()
