Hi folks, this is my first ever restoration (and 1st ever forum, thanks @Blue Shadow for some direction
I picked up a set of DQ-10's on the side of the road and they need some work. They fired up and played but there are lots of issues - I'm curious on what everyone thinks is the best "order of operation".
David
- Everything "works" but nothing sounds right. Everything is a little crunchy and distorted - especially the woofers.
- Woofers look to be original but they need to be re-foamed. What is the go-to kit? Simply Speakers? Midwest Speaker Repair? Other?
- Crossover looks to be original. I'm assuming I'll get better performance by doing a re-cap, yes?
- I've already seen lots of folks who posted purchase lists for cap's, etc. I'll dig into these - thanks.
- One of the speakers seems to have been modified - after reading other DQ-10 threads, it seems as if it's common to "mirror" one of the speakers, correct?
- Also, you'll see in one photo that there is old felt/glue residue that covered only one of the mid-range speakers. Any thoughts on this?
- Also, everything is "sticky" - the crossovers and the vinyl wrap are tacky for some reason. Even after an initial cleaning the masonite and electronics have a sticky film on them. Is this a common thing with age (e.g. infamous JBL 4328p's) or is this a one-off for me (e.g. perhaps this was environmental with where they were stored, etc)?
- Order and Refoam woofers
- Remove cross-over, clean, and do a continuity test on everything. Then rewire, and re-cap as appropriate
- Then test individual speaker components.
David
