I did some years back. Good affordable power. I've had a lot of amplifiers through my system over the years. Had a Bryston 4BST for a long stretch.I have looked at Parasound as well. Do you have one?
This is visual audio porn so I wouldn’t change a single thing!Hello all
After a year back in HiFi after a 2 decade break I have assembled a system I am happy with. It is consist's of a Pioneer SA 8800 integrated amp with a Pioneer SG9500 EQ I purchased because it was nice and a good deal and yea it looks cool to. Also have a set of JBL L5s. And a pioneer PL-550 turntable.
Now the question……
I have been pondering a 2CH amp.i would like to get one. I don’t need one I just want one. I’m very happy with the sound but I love gear too. Would a 2 channel amp change the sound a lot? I like the sound I have now.
Like I said I just want one to have one
I am considering a Adcom (cheap) or a Galion 75 watt A/B ($1500) my integrated pioneer is 80 WPC so would it be stupid to add a 75WPC amp? I am also considering a Pioneer SPEC amp depending on condition and price.
Any advice from more experienced members would be appreciated
I’m open to criticism as well as suggestions towards other amps in the $1500 or even better less range
Now I'm missing something! Initially, you say the Pioneer SA-8800 is an integrated amplifier so what do you mean later when you say it is not an integrated amplifier??A power amplifier. Not a integrated
I do not think I could do any better anywhere else. A 20 year warranty….who else does that at that price? I’m guessing no one. I think when I take the plunge I will in fact get an upgraded one….buy once…cry once.I don't know for certain why break-in takes so long, I'm guessing it's a combination of parts and circuit design. It's a custom amp, it will even have you name on it, and Klaus doesn't use cheap parts. Mine actually took longer than a month, but it's also seriously upgraded. The important thing is, once it's there, you won't care. It's as good as your preamp and speakers.
Odyssey amps are actually Symphonic Line circuit designs. S.L. is a high-end German brand, and Klaus is the U.S. importer. It's a pretty lucrative arrangement, they supplied him with the circuit designs, approved his choices of parts, and he builds them here, and sells direct, with no dealer markup. These things are practically bullet-proof.
You will get more than adequate performance from any of the amps mentioned in this thread. They'll likely all sound better than just good. And, used would likely get you a better price. But, you can shoot Klaus a number, and he'll build you an amp that will be as good as, if not better than, any of them, in my opinion. $1000-1500 can get you a hell of a nice amplifier.
And no shipping costs!
i own a integrated amp (SA8800) I would like to add a power amplifier (2CH R/L) when I say 2CH I mainly mean RL only no controls no AV No 6.xxxc no AtmosNow I'm missing something! Initially, you say the Pioneer SA-8800 is an integrated amplifier so what do you mean later when you say it is not an integrated amplifier??
A straight power amplifier will usually have no controls and only have inputs and speaker outputs but depending on make and model, some will have input level controls.
As far as 2 channel goes, every stereo amplifier, integrated, power, or otherwise, is considered 2 channel.
Left speaker = channel 1.
Right speaker = channel 2 (or the reverse if you prefer).
So.......2 channel!
Thank you. My listening space is my Living Room so it must pass with the design committee. (The wife) I can’t deny it does look nice, and as much as I cooperate with the committee the more I get to do. Like possibly add that amp. She loves music but could care less about gear. I don’t know how you could have one without the other…..LolThis is visual audio porn so I wouldn’t change a single thing!
It just didn’t show on that photoJust noticed there is no carpet on the hardwood floor in front of your system, at least in your pic. If there is no area carpet covering the floor between your listening position and speakers, adding one would really help the sound quality.
IMO, break in is as much about your ears as it is about the amp. For the amp, yes, you have to play under load. Run a 2 channel mono signal to the amp - same signal to each speaker. Wire one speaker out of phase and turn the speakers to face each other. You can run them at a good volume without much disturbance to anyone.This may be another nube.question but can the break in process be sped up by just leaving the amp on or does one need to actually play audio thru the amp to break it in?
This is what I was thinking. Acoustic treatment will give you the best bang for the buck. Some reading and experimenting and you will get improvement no amp can match. I know that one’s living situation can limit acoustic treatment options, but even minor changes can yield significant changes.Just noticed there is no carpet on the hardwood floor in front of your system, at least in your pic. If there is no area carpet covering the floor between your listening position and speakers, adding one would really help the sound quality.
I will. Thank you. As soon as I part with some of my bigginner pieces and raise a little cash I am definitely going with the odyssey. And I can probably just pick it up a few miles from home. The 20 year warranty is amazingNice rig! I think an Odyssey would be a good fit, aesthetically. For $1500, you could step it up to the Stratos, but a carefully upgraded Khartago, for the same price, will be nearly as powerful, and sound just as good, maybe even a little better. And you won't have to wonder "What if...?"
Be sure to keep us in the loop!
There is a large oriental rug in front. Just didn’t show up in the pictureIMO, break in is as much about your ears as it is about the amp. For the amp, yes, you have to play under load. Run a 2 channel mono signal to the amp - same signal to each speaker. Wire one speaker out of phase and turn the speakers to face each other. You can run them at a good volume without much disturbance to anyone.
To burn your ears, you have to listen -no short cuts. This only takes a few days.
I just looked him up and all I can say is wow.
Right here in town. I never knew. Of course I’m new to this hobby but wow. I think my decision has been made
Thank youI think your SA8800 is as good as anything. So you can be patient. I would not concern myself with sound. Do a requirements spec. What inputs and outputs? What do you want it to look like? I would be searching locally and asking questions. Have fun the research and search is the most fun.
That's really not a bad idea, and in most cases, I would agree. But, this isn't a situation where the man needs, or even wants, to correct a particular problem with the sound quality of his primary system. This is a classic case of upgraditis, nothing more. He wants a high quality stereo power amp, with no bling, just to have it. And, I get it, 100%!Here's my take - the gear that you have is all nicely equally matched in terms of performance. Here is a radical thought- look into what a parametric equalizer could do for you. It'll cost a few bucks but not $1500. I added one about 3 years ago. My son introduced me to one. I only knew about the conventional equalizer - but they are so limiting to what you can do in comparison. Even with these JBL 4435's I can get tighter punchier (at least to my ears) in the bass regions. I have a minidsp/minisharc but this article looked like it gets to the point quickly. https://unison.audio/parametric-eq/
A room correction software may also be available with the parametric equalizer.
Just a thought-
