Another yes vote, from a PX2 owner.
But one word of caution, check everything out throughly, all the functions, the start and return functions, might want to allow a disc to play thru all the way a few times. Watch where the tone arm cues when you select the size on start up. They are really well made tables, heavy as a tank, but they are very complicated with a lot of electronics inside, and a number of problems have been noted that determine the tone arm carriage operation. Not the easiest TT to work on quite complicated. There is a guy that really knows these tables inside and out, he pops up on AK once and a while member name Proffesor Blizt I beleive. He can repair them he is in Florida. That arm movement is moved along by a large wide belt which is connected to the tone arm base, has some wide pully that it runs on and the belt is connected on the underside with a pair of springs. That belt is driven by a smaller belt to the motor assembly. The eyes ( or whatever they are) I think are some kind of photo eye that when an opening comes on a plate that is what tells the arm to stop. It has a small amount of adjustment on the back. But when they go bad you have to remove the drive train rack and send it to him for repair which runs a couple hunderd bucks if I remember correctly.
