Good point, that is a big gap and a true statistical abnormally.My understanding is that the four digits following the date indicates the nth item off the assembly line & in the month in question. Our highest number is 236080294. And then nothing has been reported to the insertion point of 236080965. This suggests an outlier not only in terms of a calendar date, but that there is no evidence that the actual product count on line 23 in August 1976 is much higher than 300 or maybe 400. Statistically it is so improbable there would be such a huge gap between 294 and 965 if those nearly 700 units were ever produced yet none have been reported to our database. So we have an outlier in two respects: temporal and production line quantities if we go with 236080965.
Confirming that serial number would solve this issue. These conflicts are as old as the database itself. Almost every month when I process serial numbers I run into conflicts and have to make a judgement call. The fact that we are debating this single serial number is an example of what makes the database strong by actively weeding out erroneous numbers.I know this is detective work, and I am not trying to be argumentative. I have no personal stake in the data base. I wish I could find the AU-11000 with the same 236080065. I suspect that the AU-11000 is more likely correct but a single digit could have been misread. I have seen a number of AU-11000s listed on CAM going back several years, but not the one in question.
The last 4 digits of the serial number are less important than the first 5 but always cause these conflicts. So the judgement call is to either kick it out completely or to guess. In this case, since we can't confirm the AU-11000 but we do have a reasonably good image of the QRX-7001, I'm inclined to guess. I often guess at numbers and listed some examples in the early production outliers. This particular serial number is important because it expands the known production range, there is no question about the first 5 digits so it needs to be in the database.
The likelihood of "counterfeit" serial number tags is pretty low. This is well before computer printers so they would need to be done in a print shop. It's unlikely individual thieves would have the resources to create credible tags. I'm confident that tag is genuine and unmodified.Thinking outside the box, if fake ID serial number tags were created to hide stolen equipment, then an extensive database effort like this would eventually reveal evidence of this even if we didn't know what we were looking at.
You caught me. See how easy it is to make a mistake. So this new serial number is the second example of 1976 production.BTW You have another outlier QRX-7001 236020076. This would be two months after the last of the December 1975s were produced. This anomaly is a little more credible if it is correct. Okay. You referred to this one above, you just typod it as a February '75.
Don't stop. I need eyes looking over my work.Anyway. I am done flogging this horse.
That said, there is another interesting fact about this particular QRX-7001. The photo you posted clearly shows it's an incredibly rare single voltage North American model. The only others I've seen are 9090DBs towards the end of their production roughly two years after this one was made.
- Pete
