2017 Sansui Serial Number Database
TU777, 249090825, Lamar
TU777, 240020351, Lamar
9090DB, 817060850, Lamar
AU505, 833020744, Lamar
TU505, 834030044, Lamar
AU777A, 510030378, Lamar
Don't you just hate it when you have bad photos or damaged labels!
The R-5 could be:
R-5,861061710,marktplaats.nl
Use at your descretion.
Oh well. These were OK:
AU-217,517092994,marktplaats.nl
AU-alpha907DR,602012720,marktplaats.nl
D-390R,654014681,marktplaats.nl
D-95M,741107987,marktplaats.nl
T-510L,664031380,marktplaats.nl
T-77,830051733,marktplaats.nl
T-80,849111577,marktplaats.nl
TU-217,"028090902",marktplaats.nl
TU-217,848100198,catawiki.com
AX-7,217090138,catawiki.com
SE-8,831060767,catawiki.com
Meagre harvest this week.
8080DB,826100085,olearydq
Silver Chassis
Fuses F-2657
Cylindrical Bias transistors F-2624
Underneath F-2619
Resistors F-2656
Dolby Green ribbon cable and rivets.
Thanks, got 'um
The R-5 could be:
We have 62 R-5s in the database. None were made on line 86. All were either 84, 85 or 87. I'll put it in as 851061710.
Silver Chassis
Fuses F-2657
Underneath F-2619
Resistors F-2656
That could be the most detailed discription yet. Thanks!
- Pete
- Pete
You are welcome for the data and thank you for the compliment sir!!!!!
Another item I noticed. This unit’s front panel differs significantly from the one shown on the cover of the Service manual. There is only a single 1/4-inch headphone Jack on the left side of the chassis, versus the pair shown to the left of the unit on the SM cover page. There are no 3-position toggle switches on this unit versus the two shown on the SM cover. There is however, a pair of mounting provisions consisting of a bracket containing a slot for each of them on the chassis and open spots on the associated F-2544 PCB for the terminals and switch mounting tabs. These provisions are missing on the bezel.
Pete
Looks like some of the serial numbers don't make it to the database. For example my own equipment (post #2905) are not there. Also SP-5000A,704465,ebay.de (post #2912) and P-2000,0810168677,rehifi.se (post #2914) are missing from the database. I didn't check them all, so there may be many others missing.
First I thought it must be due to the "non-standard" serial numbers but there are many other "non-standard" serial numbers already in the database, so it can't be that. Your program may not work flawlessly.
This is the front chassis of the 8080db I am working on, showing the provisions for revised headphone Jack (one vs two on the Service Manual Cover page) and a pair of slotted brackets missing the associated multi-position switches shown on the Service Manual cover page. The PCB F-2344 does contain holes to mount and connect the missing switches, but the bezel does not contain the provisions to implement these components.image.jpg
Pete
It looks like I totally missed your units in post #2905. They didin't get copied into the months upload file. The SP-5000A and P-2000 fell out of the processing because they are non standard serial numbers. I have to enter them manually and must have gotten distracted. I'll get them all in the August report. Thank you for catching it.
This is the front chassis of the 8080db I am working on, showing the provisions for revised headphone Jack (one vs two on the Service Manual Cover page) and a pair of slotted brackets missing the associated multi-position switches shown on the Service Manual cover page. The PCB F-2344 does contain holes to mount and connect the missing switches, but the bezel does not contain the provisions to implement these components.View attachment 2953346
The same basic chassis is used for the 9090DB. The slots are for the tone crossover switches. The 9090DB also has two headphone jacks. For the 8080DB they tack on a cover with one mounting point. These aren't revisions, they represent model variations.
- Pete
- Pete
Thanks for the response. I had no idea - I thought the only difference between them was power output.
In addition to those added features, the 9090DB has walnut veneer case with beveled front edges. The 8080DB is vinyl with a flat front.
- Pete
I found some more decade errors in the database:
SP-1200 all but two of them should be 10 years earlier
SP-1500 all of them should be 10 years earlier
SP-3500 two units have decade errors
SP-3700A four units have decade errors
SP-6000 all of them should be 10 years earlier
SP-70 all of them should be 10 years earlier
A-2000,509012381,marktplaats.nl
A-7,441062683,marktplaats.nl
A-E750,656041335,marktplaats.nl
AU-217,517092663,marktplaats.nl
AU-2200,835101010,marktplaats.nl
AU-317,218110386,marktplaats.nl
AU-719,220100311,marktplaats.nl
AU-D55X,813080647,marktplaats.nl
AU-D7,221030399,marktplaats.nl
AU-X111,609125068,marktplaats.nl
CD-X301,618064708,marktplaats.nl
D-X301iR,338060598,marktplaats.nl
FR-D25,411120304,marktplaats.nl
FR-D3,409120400,marktplaats.nl
P-50,660021297,marktplaats.nl
QRX-5500,234070145,marktplaats.nl
RG-7,431050643,marktplaats.nl
T-1000L,510030182,marktplaats.nl
TA-300,"039031899",marktplaats.nl
TU-3900,847020486,marktplaats.nl
TU-666,223070113,marktplaats.nl
TU-S5,431050647,marktplaats.nl
Catawacky has too low a yield to bother. Will include them next week. Or something.
They are all fixed. A bit of database archaeology.
SP-1200, SP-1500 were some of the earliest entries in the database going back to 2003
SP-3500, The decade reference was set correctly. Those odd balls go back to 2005/2006 and must have been put in wrong.
SP-3700A, Also very early entries. The decade reference was changed at some point but the prior entries were never updated.
SP-6000, This one I put in wrong.
SP-70, The first entry was in 2007 and the decade reference has been off ever since.
Thanks for pointing these out. They will be updated in the August report at the end of the month.
- Pete
Here's something for the August report:
210,013080872,allegrolokalnie.pl
890,826030063,allegrolokalnie.pl
9090,827031016,allegrolokalnie.pl
9090DB,817040273,allegrolokalnie.pl
A-5,441060352,allegrolokalnie.pl
A-5,441061469,allegrolokalnie.pl
A-5,860121584,allegrolokalnie.pl
A-80,870030708,allegrolokalnie.pl
A-9,431080510,allegrolokalnie.pl
AU-217,828060763,allegrolokalnie.pl
AU-217II,730020889,allegrolokalnie.pl
AU-4900,857012233,allegrolokalnie.pl
AU-6500,023030398,allegrolokalnie.pl
AU-6500,813120402,hifido.co.jp
AU-9900,215070274,allegrolokalnie.pl
AU-999,021080144,allegrolokalnie.pl
AU-G90X,624110486,allegrolokalnie.pl
AU-X201i,509030263,allegrolokalnie.pl
AU-X711,601059277,audio-markt.de
B-1000,509020873,allegrolokalnie.pl
B-2201,213010032,hifido.co.jp
B-2301L,656042381,hifido.co.jp
BA-2000,246120962,hifido.co.jp
BA-F1,239030758,hifido.co.jp
C-2301,215020019,hifido.co.jp
CA-2000,238020068,audio-markt.de
CA-3000,225090175,hifido.co.jp
CA-F1,210020218,allegrolokalnie.pl
CD-X105,549111322,allegrolokalnie.pl
D-790WR,240320001431,allegrolokalnie.pl
D-95WR,605110222,allegrolokalnie.pl
D-X301i,328090050,allegrolokalnie.pl
G-5000,018031769,allegrolokalnie.pl
QR-6500,212010150,hifido.jp
QRX-3500,223091152,hifido.jp
QRX-3500,223110495,hifido.jp
QRX-3500,224020507,hifido.jp
QRX-5500,233100114,hifido.jp
QRX-5500,234120880,hifido.jp
QRX-6001,235030317,hifido.jp
QRX-6500,213062131,allegrolokalnie.pl
QRX-7001,234080530,hifido.jp
QRX-7001,234090701,hifido.jp
QRX-7001,235040351,hifido.jp
QRX-7001,244100304,allegrolokalnie.pl
QRX-7001,244120444,hifido.jp
QRX-7500,235040226,allegrolokalnie.pl
QRX-777,236030171,hifido.jp
QRX-9001,237020812,hifido.jp
QRX-9001,237050214,hifido.jp
QRX-999,237100204,hifido.jp
QSD-2,236100007,audio-markt.de
R-50,870082129,allegrolokalnie.pl
R-5L,851080530,allegrolokalnie.pl
RA-900,730033713,allegrolokalnie.pl
RG-707,633088984,allegrolokalnie.pl
RZ-1000,519070828,allegrolokalnie.pl
RZ-590,224494001018,allegrolokalnie.pl
RZ-6100AV,60300138,allegrolokalnie.pl
SC-1300,240030439,allegrolokalnie.pl
SC-1330,240021365,allegrolokalnie.pl
SC-3100G,598040703,allegrolokalnie.pl
SC-3110,597121013,allegrolokalnie.pl
SIX,824020852,allegrolokalnie.pl
SP-70,92070933,allegrolokalnie.pl
SP-X8000,97082611,hifido.jp
SR-717,325040572,allegrolokalnie.pl
S-X700,507120509,allegrolokalnie.pl
T-1000,508013268allegrolokalnie.pl
T-505,862072450,allegrolokalnie.pl
T-9,871030716,allegrolokalnie.pl
TU-217,848103011,allegrolokalnie.pl
TU-999,232020218,allegrolokalnie.pl
TU-S55X,434082839,allegrolokalnie.pl
TU-X301iL,618065893,allegrolokalnie.pl
VX-99,607041956,austin.craiglist.org
VX-99,608016009,olx.bg
VX-99,617076250,jofogas.hu
Z-9000,812070293,allegrolokalnie.pl
771,824120737,marktplaats.nl
A-E770,619123395,marktplaats.nl
AU-117,857070579,marktplaats.nl
AU-217,838110722,marktplaats.nl
AU-555A,820100265,marktplaats.nl
AU-555A,833110702,marktplaats.nl
AU-D22,432110183,marktplaats.nl
AU-505,"022050977,marktplaats.nl
TU-505,813060133,marktplaats.nl
AU-X417R,23803000197,marktplaats.nl
D-90,239102197,marktplaats.nl
G-401,858110004,marktplaats.nl
G-4700,820023132,marktplaats.nl
SD-5000,242010719,marktplaats.nl
T-80,431010169,marktplaats.nl
TU-3900,835120352,marktplaats.nl
AU-222,519060309,catawiki.com
AU-X301,508010736,catawiki.com
B-2101,634102575,catawiki.com
C-2101,674096409,catawiki.com
CA-2000,217640058,catawiki.com
DA-E55,508021767,catawiki.com
R-303,613099283,catawiki.com
R-5L,841100272,catawiki.com
T-E75L,618023458,catawiki.com
My August Harvest mostly from the Great White North
3300,223110332,CanuckAudioMart.com
800,010100679,kijiji.ca
A-40,860030137.kijiji.ca
A-40,860050315,CanuckAudioMart.com
AU-217,839010216,kijiji.ca
AU-3900,836092097,Youtube.com
AU-3900,856120284,ebay.com
AU-5900,226080063,ebay.com
AU-6600,836020159,Canuckaudiomart.com
AU-666,831040021,CanuckAudioMart.com
AU-6900,857010403,kijiji.ca
AU-717,218101132,CanuckAudioMart.com
AU-719,229090450,CanuckAudioMart.com
AU-7700,835010160,CanuckAudioMart.com
AU-777a,830060108,audiolegend.fr
AU-7900,836030262,ebay.com
AU-888,021090035,CanuckAudioMart.com
AU-9900,215111045,CanuckAudioMart.com
AU-999,831030091,kijiji.ca
AU-999,831030288,kijiji.ca
AU-D9,821060252,kijiji.ca
B-77,430101383,kijiji.ca
BA-3000,225080200,CanuckAudioMart.com
BA-F1,239030529,CanuckAudioMart.com
CA-3000,225070163,reverb.com
CA-3000,225090233,CanuckAudioMart.com
CD-10,215110070,CanuckAudioMart.com
CD-V1000,509022580,CanuckAudioMart.com
Eight Deluxe,224050021,CanuckAudioMart.com
G-5700,820080712,kijiji.ca
G-7700,810030113,CanuckAudioMart.com
P-D20,343070625,kijiji.ca
QR-6500,212060417,kijiji.ca
QRX-3500,223110707,CanuckAudioMart.com
R-7,851081565,kijiji.ca
R-7,851100366,kijiji.ca
RA-500,212110114,kijiji.ca
SC-2002,597040493,kijiji.ca
SE-88,605128423,CanuckAudioMart.com
SR-222,327040412,CanuckAudioMart.com
TU-217,848065245,kijiji.ca
TU-3900,027051282,ebay.com
TU-3900,836060130,ebay.com
TU-3900,846110457,kijiji.ca
TU-5900,026071058,CanuckAudioMart.com
TU-717,218100043,CanuckAudioMart.com
TU-7700,815060006,CanuckAudioMart.com
TU-7900,027020435,CanuckAudioMart.com
TU-919,210010229,CanuckAudioMart.com
TU-9900,836020267,CanuckAudioMart.com
TU-999,231030184,ebay.com
