2017 Sansui Serial Number Database
Thanks, got it! Your AU-7900 was built in April of 1977. It was the 631st unit off assembly line 22 that month. In additon to producing AU-7900s, line 22 was also producing
AU-607s and AU-707s that month.
- Pete
The harvest for week 13:
A-E350,436092733,marktplaats.nl
AU-101,581090736,marktplaats.nl
AU-101,821030223,marktplaats.nl
AU-117,848082416,marktplaats.nl
TU-217,848040077,marktplaats.nl
AU-417,219020268,marktplaats.nl
AU-505,832110994,marktplaats.nl
AU-D33,574070998,marktplaats.nl
TU-3900,025090181,marktplaats.nl
AU-X301i,508080269,marktplaats.nl
D-70BW,436102114,marktplaats.nl
SR-525,325121843,marktplaats.nl
T-60,840081375,marktplaats.nl
T-77,830120227,marktplaats.nl
TU-666,231100247,marktplaats.nl
TU-666,222030248,marktplaats.nl
AU-555A,820111753,marktplaats.nl
TU-666,240090098,marktplaats.nl
TU-7700,224080159,marktplaats.nl
TU-S33,833010404,marktplaats.nl
TU-X301iL,608056842,marktplaats.nl
AT-700,616062081,catawiki.com
AU-D7,221040240,catawiki.com
TU-S7,431070976,catawiki.com
B-1000,507090816,catawiki.com
C-1000,507121272,catawiki.com
G-7000,"038030238",catawiki.com
SE-5,580x00141,catawiki.com
SE-7,510090119,catawiki.com
SE-8,831070875,catawiki.com
TU-555,240050362,catawiki.com
TU-S9,812110014,catawiki.com
Thanks. I'm going to start processing this months submissions this morning. Looks like about 800 serial numbers.
- Pete
Here's the March stats:
804 serial numbers posted. 644 new serial numbers added to the database. Most of the duplicates were already in the database but there were some that couldn't be processed.
P-50M,345010532,kleinanzeigen Couldn't find this model
SC-1110G,248090430,kleinanzeigen Couldn't find this model
SP-U3000,928010949,kleinanzeigen Couldn't find this model
STR-6055,901405,elektro.bazos.cz Sony?
S-X100,507071775,kleinanzeigen Couldn't find this model
T-100,646101655,kleinanzeigen Couldn't find this model
APS-1400,94905364,yahoo 3rd digit can only be a 1 or 0
SC-1,24811059,yahoo missing a digit
SE-5,580x00141,catawiki.com invalid character
SE-99,215691147,kleinanzeigen 4th digit can only be a 0 or 1
TAC-505,23040232,yahoo conflict with AU-6500 in database
Please check these entries to see if the errors can be fixed
Thanks for all your help with this ongoing project.
- Pete
- Pete
These kleinanzeigen ones look like mine. One was a typo from me
S-U3000,928010949,kleinanzeigen
SC-1110G(?), SE-99 are already gone
Same for these x-100 and P-50M which were some of these plastic stuff compact systems or something. But also gone, so I can't correct these or link for proove.
The serial number 248090430 is consistent with the SC-1100G's in the database. And there was an SC-1100G on Kleinanzeigen from March 18th to 20th.
Was this a typo of the model number?
However, the SE-99 serial number is way out of range. So far all the SN for SE-99 begin with 60, 61 or 62.
- Pete
STR-6055 is a Sony receiver. That was my mistake. I apologize. The serial number was correct though :)
If you can't see or read a digit, make your best guess and add a note. Then I know what to do with that serial number.
All of the serial numbers are in an Access database. I use a second Access database to process the new serial numbers. I copy and paste the posted serial numbers to a Word file. Some time ago I posted the steps to format the raw posted serial numbers and remove duplicate postings. The serial numbers are put into an Excel file to remove the duplicates.
Access is totally unforgiving, everything has to match exactly. The first process in Access is to add a "decade reference" to the new batch of serial number. The formatted excel file is imported into an Access table called Decade Update. A "query" compares the model names in the new batch of serial numbers to a "Master Model Table." Each model cataloged in that table has a decade reference tied to it. If the model name exactly matches a model name in the Master Model Table, the decade reference is added. If it doesn't match, the decade field is blank.
Here's an example (picked at random)
AU-D707XCD Decade
AU-D 707XCD Decade
AU-D707 XCD Decade
AU-D707X CD Decade
AU-D707XCDDecade
Access sees this as 5 different models. Only the first one is correct. If you add or subtract letters it creates even more variations.
The model name has to match exactly. Sansui used too many different prefixes and suffixes. All the letters, spaces, dashes, word and anything else in the model name has to match exactly. It's not uncommon to get some of this wrong. In many cases, it's just a matter of shifting the spaces into the right sequence and I move on. If letters are added that shouldn't be or letters or names missing it creates what appears to be a previously unreported model variation.
Almost every month you guys find models that need to be added. Before I add a model, I do an internet search to physically see that new model. This does a few things, It verifies it's a valid new model, it confirms the model name and it helps assign the model decade. In many cases google finds it quickly but if not, I dig in to find some truly rare models. Chasing mystery models that don't actually exist is time consuming and frustrating so please be careful.
Look at the ID plate on the back of the unit to see what Sansui called it. This works most of the time except with words like Vintage, Limited, or Extra. Sometimes those names only appear on the face of the unit and are not always included on the ID plate.
\end rant\
- Pete
Welcome to the Sansui Serial Number Database thread. The database now resides on Sansui Page in Digital Docs. You Can Access it here:
Please post new serial numbers in this thread. They will be uploaded to the database at least monthly, more often if needed.
When posting serial numbers please use this format:
Model,Serial Number,AK User Name
9090DB,827011234,LBPete
G-9000DB,818021234,AK User Name
AU-555A,581080009,AK User Name
No spaces but please place a comma between data points. The commas are important. List multiple serial numbers as indicated. Please do not add anything else. I have to delete it when I create the upload file.
This format is changed slightly from Paul's format but it's easier for me.
Thanks, got it! Your AU-505 was built on production line 83 in April 1974. It was the 905th unit off that line that month. Line 83 also produced TU-2000s and AU-2000s that month. It looks like most units produced on that line at that time were built by contractors as indicated by T-tags.
Does your AU-505 have a T in a circle on the ID plate?
- Pete
Hi Pete,
I feel your pain. I've come across similar issues with additions like EXTRA and such.
Here's my harvest for week 14. Fortunately no weird models:
A-7,441041807,marktplaats.nl
A-80,860010869,marktplaats.nl
CD-E70,67201377,marktplaats.nl,not a 9 digit serial
CD-X301i,608045107,marktplaats.nl
D-X301i,328081236,marktplaats.nl
D-X501,328020911,marktplaats.nl
TU-X501L,608028953,marktplaats.nl
C-77,830051519,marktplaats.nl
TU-717,847061542,marktplaats.nl
TU-S55X,434082957,marktplaats.nl
TU-S9,210100219,marktplaats.nl
881,824102369,catawiki.com
AU-999,210060305,catawiki.com
CD-X617,15201000527,catawiki.com,not a 9 digit serial
FR-D35,411041470,catawiki.com
G-7000,038030984,catawiki.com
P-M50,324093073,catawiki.com
QS-500,832050047,catawiki.com
SE-8X,474022014,catawiki.com
TU-217,848052462,catawiki.com
- Pete
There is a circle T w/ a bar over the T. I changed the small value caps. Hooked up my equally old Toshiba table. AU 505 out performs pretty much all my other amps for phono listening. Thank you for the info.
CD-alpha 907i,317110067,kleinanzeigen
Dann, the thing is 40km away from my hometown, but 100V and "Front door doesn't open"
it does happen, my 2nd MA-7 was a non-specific HiFi Shark search find and it was 21 klm from me in Melbourne AUS...and with a TU-317 AND both mint hardly used!!
WK15 harvest:
350,128122683,catawiki.com
9090DB,817033644,catawiki.com
AU-555A,833030951,catawiki.com
CA-3000,236020410,catawiki.com
D-590R,615068518,catawiki.com
SE-3000,311060220,catawiki.com
TU-666,232120392,catawiki.com
A-5,441122979,marktplaats.nl
AU-666,"021050269",marktplaats.nl
AU-D9,822020084,marktplaats.nl
AU-X301i,530010563,marktplaats.nl
D-80C,674091512,marktplaats.nl
G-9000DB,818090647,marktplaats.nl
SC-2100,598010260,marktplaats.nl
SE-7,582080948,marktplaats.nl
SR-B200,479070644,marktplaats.nl
T-5,431021606,marktplaats.nl
T-60,840051521,marktplaats.nl
T-707,862073090,marktplaats.nl
TU-217,848050325,marktplaats.nl
TU-777,249091146,marktplaats.nl
TU-S55X,614057305,marktplaats.nl
There was even a serial stuck on a box. Didn't know Sansui did that but makes sense of course:
