2017 Sansui Serial Number Database
The harvest for Allegro's Archiwum for 2019H1 is now complete (attached). 167 serialz. It was a lot of work, maybe I should take a hiatus for awhile.
I now have 3996 serialz in my own upload database...
Another question: what should I do with Blaupunkt/Artech serials? These are valid Sansui serialz and production but seem to be discarded when I post them. AFAIK it is a single tuner and amp (AU/TU-X317 if I recall correctly).
ARTECH PX / MX 5090 = SANSUI B 2102 / C 2102
Nice work on the Archiwum archive. I've copied them into the August file.
I see you have started to include T-tags. The T-tag designation has it's own field so please separate it with a coma or in some cases two commas. There are a total of 5 fields in the master serial number table, Model,Serial Number,Reporter,Notes,T-tag. As you probably know, each field is separated by a comma. If there is a note like JDM in the 4th position then place a coma before the T-tag. If the note field is blank please use two commas so the T-tag destination skips over the note field. Model,Serial Number,Reporter,,T-tag
The T-tag designates the unit was assembled by a contractor. In many cases that contractor's name is after the T-tag. The most common one is SOC. It's good to have that name along with the T-tag.
Frankly I've been avoiding the whole question of the re-branded models. Although they were made by Sansui they didn't have the Sansui name and were sold through other distribution channels. At the same time they add to the production range of the base model.
The problem is how to tie the base model and the rebranded models together so the production numbers add up. I guess at the very least I can put them in a separate table and then figure out a way to tie them together. It will require something like a union query tie the models together. Let me think about it. In the mean time please list the rebranded models separate from the Sansui models so I can put them in a separate table.
@Akca thanks for posting. Your AU-717 was built on production line 22 in August of 1977. It was the 1,?71st unit off that line that month.
I´d wager 227081571.
Or 227081371. I'll put it in with a note.
- Pete
Noticed this one not listed in the database unless I missed it. Was submitted back in 2022. Will submit again since it is now fully functional.
800,029041025,dly66
Marginal harvest for WK34:
A-1000,508060493,catawiki.com
A-E970,499092472,marktplaats.nl
AU-217,837082543,marktplaats.nl
AU-D101,573080459,marktplaats.nl
AU-D22,634050550,marktplaats.nl
AU-X417R,23003000561,marktplaats.nl
DA-P550,605057584,marktplaats.nl
SR-222,326121153,marktplaats.nl
T-7,861042689,marktplaats.nl
TU-555,231010592,marktplaats.nl
Slowly chugging through Allegro's archiwum. Expect to have 2019H2 completed for next month's run. Maybe even 2020H1, who knows.
800,029041025,dly66
Thanks, I'll make sure it gets in this time.
Interesting, it seems to use a very similar logic as the macro our database uses to decode the serial number. I wonder if he saw the discussion on the MS Access forum where we were discussing the coding of the macro.
@PE9ZZ, @milo63 I have your serial numbers too.
- Pete
kw34 harvest on kleinanzeigen:
8010,824090133,kleinanzeigen
A-80,879093296,kleinanzeigen
A-909,432115198,kleinanzeigen
AU-117,838022031,kleinanzeigen
AU-X417R,23903002749,kleinanzeigen
AU-G90X,436044182,kleinanzeigen
AU-X911DG,619082630,kleinanzeigen
AU-719,229090692,kleinanzeigen
AU-317II,839040773,kleinanzeigen
AU-X701,627074580,kleinanzeigen
AU-9900A,247010462,kleinanzeigen
AU-D9,821060007,kleinanzeigen
C-2101,664121383,kleinanzeigen
CD-X301i,438091304,kleinanzeigen
D-95M,481083611,kleinanzeigen
G-9700,819061193,kleinanzeigen
MAS-1500,2132004242,kleinanzeigen,same number for the pair of two speakers
P-E350,917010532,kleinanzeigen
QRX-7500,234100897,kleinanzeigen
RZ-1500,12003003312,kleinanzeigen
SP-X8700,909030791,kleinanzeigen
SR-222 MKV,315071526,kleinanzeigen
T-909,872102113,kleinanzeigen
TU-217,848102686,kleinanzeigen
This week showed a lot of "beautiful amp, just volume pot is scratchy" multiple times. Nearly half of the amps had this description included with more or less the same wording by the people trying to sell their amps.
Finished 2019H2 of Allegro's archiwum. I found a new device, two RG-770s with non-Sansui serials. Prolly a rebadged OEM unit. Also an outlier with a dubious serial (SR-232):
Feel free to discard. I myself tossed many, many more...
In total 133 new serialz that are not in the database here nor in my own (4138).
Got 'um. I'll look into the SNs that indicate a conflict before I start processing the month's batch on Saturday.
- Pete
My August 2024 Report
300,219110312,canuckaudiomart.com
4900Z,821011038,hifistereo.nl
4900Z,821030312,canuckaudiomart.com
551,815120293,kijiji.ca
9090,826082870,canuckaudiomart.com
A-80,860040041,canuckaudiomart.com
A-M7,872020124,kijiji.ca
AU-10000,237010448,ebay.com
AU-11000A,218010129,canuckaudiomart.com
AU-2200,915040468,kijiji.ca
AU-4900,836070265,kijiji.ca
AU-4900,916040166,youtube.com
AU-519,210010049,kijiji.ca
AU-555A,820111439,canuckaudiomart.com
AU-555A,830091052,canuckaudiomart.com
AU-6500,813090601,kijiji.ca
AU-707,227120712,kijiji.ca
AU-7700,814110595,youtube.com
AU-777A,830030192,gumtree.com.au
AU-7900,247060185,canuckaudiomart.com
AU-8500,214060118,canuckaudiomart.com
AU-D907 Limited,229120283,kijiji.ca
AU-G99X,604123737,canuckaudiomart.com
AU-X501,608097109,canuckaudiomart.com
BA-3000,225080503,canuckaudiomart.com
BA-3000,246040082,canuckaudiomart.com
BA-90,139020036,canuckaudiomart.com
D-990R,644061374,canuckaudiomart.com
QRX-7001,234110991,canuckaudiomart.com
S-45U,11485,canuckaudiomart.com
SEVEN,824020645,kijiji.ca
T-80,840030332,canuckaudiomart.com
T-M7,872022582,kijiji.ca
TU-417,849030633,canuckaudiomart.com
TU-7700,224102581,youtube.com
TU-7900,027020019,canuckaudiomart.com
TU-7900,027020574,canuckaudiomart.com
TU-9900,848050026,canuckaudiomart.com
TU-S9,833020176,canuckaudiomart.com
A lot of missing and illegible tags as usual. Not to mention so many already in the database.
My harvest for WK35. Hopefully it can be included in the database update for August:
A-80,420093349,catawiki.com
AU-117,857070762,catawiki.com
AU-217ii,219021286,catawiki.com
AU-217,848081481,catawiki.com
AU-5900,856110791,catawiki.com
SC-3003,587010145,catawiki.com
T-500L,646011593,catawiki.com
T-80,840060165,catawiki.com
TU-5900,026120381,catawiki.com
441,024111345,marktplaats.nl
771,014021950,marktplaats.nl
AU-5900,836100941,marktplaats.nl
AU-X201,508011387,marktplaats.nl
D-300M,752021239,marktplaats.nl
D-90,230090151,marktplaats.nl
D-X301i,328083063,marktplaats.nl
FR-D3,319041756,marktplaats.nl
SR-333,318120094,marktplaats.nl
SR-535,328060645,marktplaats.nl
SR-B200,479050421,marktplaats.nl
The T-500L is from a production line not in the database for this model:
