Hi Pete,
Pse. add to the Sansui serial number database:
SC5300,250100510,antpaubarcar
Thank you
Thank you
I'm not sure what you are asking here. An on-line translator gives me this: "serial number tells you when and where to publish"seri numarası ne zaman ve nerede yayınlanacağını bildirir.
Wow, a real international group of posts. Thanks guys. They will be in the January report.
Here is the information contained in the serial number:
The first two digits indicate the production line.
Third digit is the year of manufacture
4th and 5th digits are the month of production
The remaining 4 digits are a sequential number
AU6900 836100430 - Production line 83, October 1976, the 430th unit off that line that month
AU555A 831090983- Production line 83, September 1971, the 983 unit off that line that month
The first post in this thread has a link to the latest Database Report.
I hope this helps.
- Pete
AU-9500,214030567,FuzzywunWelcome to the Sansui Serial Number Database thread. The database now resides on Sansui Page in Digital Docs. You Can Access it here:
Please post new serial numbers in this thread. They will be uploaded to the database at least monthly, more often if needed.
When posting serial numbers please use this format:
Model,Serial Number,AK User Name
9090DB,827011234,LBPete
G-9000DB,818021234,AK User Name
AU-555A,581080009,AK User Name
No spaces but please place a comma between data points. The commas are important. List multiple serial numbers as indicated. Please do not add anything else. I have to delete it when I create the upload file.
This format is changed slightly from Paul's format but it's easier for me.
Hi Pete,Almost all the information we have on production lines comes from the serial numbers themselves. Often when a model was first introduced all production is from a single line. As the model ages, often the production would shift to a different line. Here are some examples:
We have 5 SC-5300s on file, all were produced on line 24
We have 21 G-6000s on file. Based on this sample, Production started in February '78 on Line 02. In April '78 it moved to Line 81 and in May it moved to Line 85.
Your G-6000 was built in May of '78 on line 85. That month G-7000s and G-8000s were also built on that line.
All 16 of the SR-838s on file were built on line 31.
Some of the lines seem to be dedicated to certain types of models. Line 85 produced mostly receivers. In other cases a line is used for many different models. The database shows that line 31 produced at least 34 wildly different models in its history.
Some day when I have time I'll try to list models and production lines.
- Pete
Line 83 was definitely an in-house line. A lot of "core" models were built on it.Hi Pete,
Thank yo very much for your reply, I thought that maybe there was more info. on the production lines.
I also saw yesterday that my Qs 500 and all I could find on Ebay showing the back pannel have the T SOC on it and all listed on AK
were made on p.line 83 so maybe p.line 83 was an outsource!?
Thanks guys!
- Pete
I have no idea, can you post a picture?
- Pete
I never noticed that before. Don't know for sure but my guess is that is some sort of compliance seal for some export market, similar to the UL certification we have here.what the T SOC in a circle means, any idea?
Hi Pete,Got it, thanks!
- Pete
That's a very interesting link. It's the first time I've seen any identification of contractors. It needs to be discussed in the main Sansui forum to see how widely known the t-tag is.Hi Pete,
on another post = Sansui Sr 838 custom feet
Sansuiman send a reply about subcontractors with this link about the circle
with the T-tag
http://www.thevintageknob.org/tvk_talk/viewtopic.php?f=0&t=2395&p=5574&hilit=T+tag#p5574
Pse. Take a look and comment
- Pete
My friend Axel did a hell of research on this matter before publishing it; too bad that he has stopped working on TVK, but there were a various reasons for it.
Besides that the T-tag was used for contractor (location) identification on JDM electronic equipment, that tag symbol actually stands for "postal code" in Japan. From wiki:
〒 (郵便記号, yūbin kigō) is the service mark of Japan Post and its successor, Japan Post Holdings, the postal operator in Japan. It is also used as a Japanese postal code mark since the introduction of the latter in 1968. The mark is a stylized katakana syllable te (テ), from the word teishin (逓信 communications).
