2017 Sansui Serial Number Database
Hi Pete,
9090, 826050192, mea2112
This unit was manufactured in May 1976 correct? If so, it shouldn't need any service bulletin work right?
Thanks, Mike
Got them. Thanks.
826050192 was built in May '76. It's right on the cusp of when the production change was supposed to take place so it would be a good reference to see if the date in the bulletin is accurate. Can you take the cover off and look at the driver board? Does it have fuses in plastic sleeves? If so, it has the mod.
- Pete
Got 'um. Thanks guys. The July file has already been processed. These #'s will be added to the August file.
- Pete
Rob Mangieri
BA-5000 245110107
BA-5000 I cant find the white tag on it would the SR be anyplace else on the unit?
BA-3000 22508825
BA-2000 217070991
BA-2000 217060377
BA-F1 239050296
BA-F1 219070336
CA-F1 239060030
CA-3000 225120274
CD-10 210810053
TU-517 218040465
Still to add later
5000x
2000x
AU-717
AU-717
Not sure I put this one in or not but it's going out the door today
400 Receiver, 017114200, Windwalker
Got them, thanks.
Super98lsc, that's quite a collection. If there is no tag on the back of the BA-5000, it must have gotten lost at some time. Sadly there's no other record.
- Pete
Welcome to the Sansui Serial Number Database thread. The database now resides on Sansui Page in Digital Docs. You Can Access it here:
Please post new serial numbers in this thread. They will be uploaded to the database at least monthly, more often if needed.
When posting serial numbers please use this format:
Model,Serial Number,AK User Name
9090DB,827011234,LBPete
G-9000DB, 818021234,AK User Name
AU-555A,581080009,AK User Name
No spaces but please place a comma between data points. The commas are important. List multiple serial numbers as indicated. Please do not add anything else. I have to delete it when I create the upload file.
This format is changed slightly from Paul's format but it's easier for me.
