2220B H216 Diode?
milo63
Everett, WA
Working on a troubled 2220B, someone has spilled some liquid on to the P100 board and it corroded a bunch of component leads.
H216 is a 20A 90M diode and nobody has seemed to have had to replace one per the search function.
Weird how they numbered it, I was thinking the original is an OA90, no "2" in front. I bet the 1N60 works fine.
The "2" indicates a matched pair. H215 and H216 are matched and used in the ratio detector. Mismatched diodes may increase detector distortion. Schottky diodes may not work well as substitutes.
Great....how does one match germanium diodes if one can find real germanium diodes?
Thanks for clarifying and reminding me that I hate tuners.
"Great....how does one match germanium diodes if one can find real germanium diodes?"
Use your DMM in diode test mode, lead clipping probes. Match for the same or very close to the same readings.
I would buy any P200 you can find and scavenge 1N60s from there.
FWIW, I seem to remember from many yrs. ago that 1N34(A) is a Germanium small signal diode that was commonly used as modulation detectors in both AM & FM receivers.
Just a suggestive thought.
Thank you.
I bought the cheapest P100 board (2270) on eBay to cannibalize the 1N60 diodes from, it has a bunch so I should be set for life
