OakBayou
First, let me thank everyone who participates here past and present. This forum is the primary thing that got me into vintage gear, and built my knowledge and confidence to try to conserve the Marantz magic for future generations.
I've gotten myself into a pickle with this unit and hoping I can get some help and advice. I'll write up some backstory in another post, but for now, I'm trying to find a short or bad device that is causing me grief.
While testing with a scope and the heatsinks off and volume up to near clipping running on a dummy load--probably not my best idea--the unit blew the main fuse.
After replacing the fuse and starting on a dim bulb, I get nothing. Measurements of various transistors, diodes, and some resistors like R776 (100Kohm) on the power supply seem to fluctuate all over the place, off power and on the dim bulb. I had built a snubber and had it installed across the main power wires on the new switch, but then realized that there was already a snubber in the back of the unit across the two power outlets, so I removed it. Tested continuity from mains in to switch, and from bridge rectifier to power supply. Looks good.
I decided to at least finish recapping, so got that done. I "practiced" soldering on this thing years ago, using crappy Radio Shack lead-free solder. Two traces had lifted due to higher heat with a cheap iron, and I noticed a cold and broken joint. I have better tools now. I removed all the lead-free with wick, carefully scrapped away some solder mask with a razor, and soldered the new caps in here with the leads bent down onto the freshly exposed copper trace. The connections look very good to me.
Next I pulled out the main filter caps and tested the bridge rectifier. Looks good. Tested Q750, the large power supply transistor (2sd 330). The measurements off-power, in-circuit looked bad, but I pulled it out and it seems to test fine, about a half volt drop.
The lamp dial has a different supply from the transformer that passes through a fuse and a diode, so I started to wonder why at least the dial didn't power on. I tested Q749 (WO6B), off-power in-circuit it looked bad with only reverse readings of 0.96v and OL forward biased. Out of circuit, it tests fine at 0.556v forward. Is this even possible? Is my DMM bad?
I haven't tested output transistors yet, but I've already got replacements for them (the infamous batwing 2SB617 and 2SD587).
OK, where should I go from here? After the diode test, I'm a bit stumped.
