2230B Vs. ....... 2230B?
klamsoss
Be willing to fail and try again.
After spiffing up a 1060 and running my mouth about it at the local record store, the owner of the shop asked if I'd be willing to recap a Marantz he'd just sold, before he sent it to the new owner. I jumped at the chance. I figured it couldn't be that much harder than the 1060, and definitely no more difficult than the tube units I have worked on.
Aside from the fact that it weighs about 55lbs, it doesn't look terrible. Boards have reasonable space and are accessible enough that I shouldn't have to do too much disassembly to access everything.
I know it worked reasonably well before I took possession. The guy said "it sounded a little scratchy when anything was adjusted, and I only listened through the headphones. I don't need anything fancy. Just want to make sure it's good to go for the next several years." The buyer doesn't plan to use the tuner section, and I don't have an RF generator or spectrum analyzer, so I plan not to touch it. Is it true that if you replace caps in the tuner, you have to redo the alignment?
I figure I'll do all the electrolytic caps except the tuner, replace diodes here and there, and anything that is visibly damaged. Then hit it with deoxit and lube pots, switches etc. Finally, fire it up and set everything in the power and pre amplifiers to factory specs. Then I'll just have to figure out what records I want!
The problem I am having is that there appear to be 2 versions of the 2230B. Yes, I know the 2230 is not the same as the 2230B. I'm saying there appear to be multiple, very different versions of the "B".... I've attached a pic from a restoration thread here on AK, and a pic of the one I have. Notice that one has dual power amplifiers within it! It also uses two multiple section caps that are 6800uf+6800uf, and the transformer is about 4x the size.... easy to tell these ain't twins.
I found a service manual online but it's clearly for the one that has single 6800uf caps and not the version I have on the bench. Can anyone shed light on these differing versions? And possibly point me towards the service manual for my version? I can replace like parts with like but I'd like to have the manual for when I fire it up and set balance, bias, and offset.
Many thanks.
Weird. Service manual for 2230B shows a completely different receiver. You sure this is a 2230B? Care to post more piccies? Front panel, rear label/serial number?
As for recapping, is it working now? Also, if you have no RF test equipment, best leave the tuner alone. But if you really, really feel the need of replacing electrolytics in that area you should be OK. Just don't touch anything else.
I have owned 2 2230B and have seen a few others but never have I seen a 2230B with 2 dual main filters and a transformer that big!
Pretty sure what you have there is a 2330B.
They're not too bad. Most time consuming part is the main filters. There are no direct drop in replacements for them. Couple of options. You can either open them up, gut and restuff them or you can make your own board (laser printer/etch method works well) and mount it on standoffs in thier location. I've also seen others use two separate caps to fit in the original clamps.
I like the restuff method as it retains the original look. Those cans I believe are the same ones that the 140 power amps uses but only 1.
The fm section is tough to access the solder side of.
Be very careful with the shaft removal of the selector/phono board. I've encountered loctite on the set screws there that were a pita to remove.
Bryan, you da man!
I'm going to restuff. Good tip on the selection/phono... I was kinda wondering about that. I'll be extra careful.
Since it is working well enough, I plan to NOT do anything extra. Just electrolytics and deoxit, basically. I'll report back here when I get my parts in.
Many thanks!!!!
:( what do you guys know that I don't? A straightforward recap doesn't seem too hard on this. Granted the dual section caps will be a PITA but I'm used to restuffing cans from working on tube amps. Are these caps similar to the silver ones you see on Fisher and Eico tube amps in terms of internal construction?
Is there more of a hassle in for me than I realize?
It’s a pretty big receiver and the power supply board is challenging to access. If you’re only doing the caps it’s not that bad. I had to rebuild an extremely fried amp board on a 2330B and it took a lot of time.
