Sounds like you found the problem, R808. If the Zener was shorted, it would connect it to ground.
If zener was shorted R808 would be connected to ground and power thru R808 would be:
P = V^2 / R = (44)^2 / 3300 = 0.6W. R808 is a 1/4W = 0.25W resistor, but the voltage there looks good. You didn't change any electrolytic caps and by chance put them in backwards by mistake, did you?
R806 is a variable resistor. It should read 5k ohms across the outer two leads. The center lead is the tap, or wiper and will vary with rotation.
