Steelman
I just picked up a Marantz 2270 last week and just got around to putting it on the bench.
I first noticed the bulbs were very dim with a greenish blue tint to the display and input indicator bi pins. I figured a good cleaning and vellum replacement was in order. The vellum was indeed yellowed thus the green tint so I removed the dial panel and removed the vellum.
I noticed the bulbs were replaced and suspected they may be different voltages (thus the dim yellow illumination) so I pulled them all and replaced them with new 8v 200ma's I had on hand. No dice...same dim illumination.
I pulled out the Fluke and measured each dial lamp and read 7.13 vac. The bi pins measured 6.3 vac.
The stereo indicator bi pins is out as well...measured the pins and there is no voltage on the pins at all. All the bi pins seem to be original.
Any Ideas was to where to start?
OPT? Power supply board?
Thanks in advance,
-Vincent
Thanks in advance,
-Vincent
...I assumed the stereo indicator was AC like the other bi pins. No wonder I was getting a "0" reading.
