2270... first restoration questions
So... here are a couple pics of my board..
I have a revised first edition service manual that is for serial numbers 1001-4900... my unit is see #6096... where do I find the correct schematic or manual.. any help is appreciated..
I have been looking at your thread and the one attached to it... it is very helpful... you guys are so helpful with us newbies... it looks like R-809 was replaced but not sure what with? Is H-803 the transistor mounted off the board with the blue, white, and yellow wires soldered to it... in your picture it appears the flat replacement has the base leg cut off... maybe it it just bent from view in the picture... I didn’t replace this one so I used your list and have ordered a replacement... ( I actually have purchased your complete list for the 800 board as I’m thinking of starting the restore over from scratch as I have learned so much already ) I think there are a couple typos in your list but I believe I figured them out !
Yes... with so much going on the rebuild, it is good to do some double checking (no one has vetted). Not my favorite unit to work on = fosho. Hope it helps you out. Was happy with the results.
Good Luck.
Good Luck.
Ok... I’m a bit confused or I just made a bad assumption... the attached picture is from A spec sheet from the transistors I ordered from your list... my assumption has been that the center leg is the base... this picture leads me to believe otherwise... please confirm the configuration..
