Jamie Starr
Guys: I am restoring a 2275 and have distortion issues in the left channel. I have narrowed it down to the left power amp.
The distortion problem was there when I obtained the receiver. I initially thought it was just really dirty pots. I then thought it may be the tone board. But I have definitely ruled those out. (I have a working 2275 and swapped out the amps. No distortion when I do that.)
The distortion begins to happen after about four minutes of running the amplifier. That’s what kind of threw me off. I thought I had the problem solved but did not.
Any suggestions on where to look? Output transistors? Cold solder joint? The fact that it doesn’t show up for four minutes is some kind of clue. Thanks for your help. I have already recap the board.
