ZeroG
I've been recapping a 2275 one board at a time. After recapping the phono board I found the left channel was out completely. I had replaced the 3 electrolytics, the two tantalums, and also the two 2SC248 with KSC1815.Left channel is completely out on phono, not on FM/AM. I checked my work (again and again, as always) and everything seems to be in correctly. I matched the new small signal transistors before installation.
Of course, this is the one board I didn't test prior to recap because I didn't want to bother with unhooking my turntable, etc. Naturally this is the one with issues.
Then, I decided to check if the left channel was getting any voltage, and this is what I found:
Between J408 and J405 - 35V
Between J407 and J404 - 0V.
Should the voltages be equal at both test points? And where else do I look for the cause of the left channel being out?
Thanks in advance for assistance on this, I really appreciate it.
