ZeroG
Double check the wire wrap connections on J401 and J403.
Maybe something is shorting out when it's mounted. It should operate fine with the board loose.
Tom
Thanks for your input, Tom. I've left the board loose, and have been checking the collector voltage on H405 each time I try something, and it's always 0.6V. The wire wraps on J401 and J403 seem OK, pic attached. I still re-flowed the solder on the solder side, just to be thorough.
